At starting cpu no display,three four times shutdown then it work
When i starting my computer there is no display , after thre to four times shutdown then it works,
  • 1 more comment
  • WillCMarg Dec 01, 2008
    system would not want to start up, until after 2-5 times. now won't start up, excep to have hard drive light on, No display. Changed CMOS battery, no change! will not start!
  • Anonymous Dec 15, 2008
    I have the same problem. I use now an old PCI card to startup, because the AGP is not recognized anymore (nVidia Quadro FX). If you have an AGP card with DVI and VGA output, maybe try first the VGA one, before you try the PCI card. But anyway: I come to the BIOS and can change and save something, but I just can't start windows anymore. It happened after I installed some new passive coolers - but the temperature is still okay, I don't understand this.It seems, it is defect now ...
  • meister-petz Dec 15, 2008
    Sergeant:
  • 177 Answers
Try replacing the motherboard battery.
Posted on Nov 26, 2008
Aspire z3-105 ...three beeps then three more but computer still will not start....removed the two 4gb cards,cleaned and replaced still no start. Help....
Remove the CPU and CMOS battery from their sockets and press the power button of the chasis without connecting the power cable for 1.5minutes. After that place the CPU back into its socket and connect the power cable then power on the PC, it should power on and boot. After powering on Setup the BIOS settings and shutdown the computer and place the CMOS battery then you will be good to go.
May 20, 2017 | Aspire Computers & Internet
My HPdv6910 has stopped working. I see the power light and battery light on but the hard-drive light is not on and the screen is blank even after I plugged it for more than an hour
reset boot formate to f12 but first lets get that blank screen off keep pushing f2 f2 f2 f2 thre or four times intell first page starts up then push f2 then use arrow keys on key board and at bottom booting log you shoud be set up on f2 change boot log f12 then pressf10 to save restart computer then when computer starts up push f12 then run windows under d: drive the it will ask you start windows run windows from disc or trouble shoot go to run windows after that you shoud be ok.
Feb 17, 2011 | HP Pavilion Dv6910us Notebook
I was using the computer for a short time, just reading news on the internet when it beeped three times and the monitor went blank and the mouse and keyboard also stopped working. I had to do a hard...
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Sep 23, 2010 | Gateway FX7026 PC Desktop
The computer shutdown and I tried to turn on and
If you are getting through the bios before it shuts down, you may want to make sure that the CPU cooling fan is working and that there is plenty of airflow around the CPU heat sink. Make sure the reset and power buttons are working properly as well. Check that all of your RAM modules and any add on cards are seated properly as well.
Jan 03, 2010 | HP Compaq Presario F500 F700 and G6000...
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Charger of my v3i unable to charge.
probably a bad charger try someone else's I had this happen once from the many phones i had (that and the dog ate the wire on another)
Jan 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Computer turns on but no display/cpu_fan slot not working.
The four-pin CPU fan connector is the same as the three-pin (red is for voltage, black is ground and yellow for the rpm reading) but also adds a blue wire used by some BIOS sets to adjust the RPM speed of the fan. The three-pin will fit into a four-pin connector without modification, using a jumper is DEFINITELY not recommended as it could short your board.
If your system has the four-pin fan, and it boots and runs without error, it may be that your CPU is running cool enough that the fan is not needed at the time. Check your BIOS for a hardware monitor to see the actual CPU temperature. Also, you may have added utilities in Windows to give the fan speed and CPU temperature in real time. You may also notice the CPU fan kicking in when doing CPU intensive operations (virus scans, etc.)
The four-pin fan would run from a three-pin connector but would always run at full speed because the RPM Adjust signal is not present.
Dec 27, 2008 | Intel Motherboard
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
641 people viewed this question
David Payne
David Payne
