Question about Dryers
Where do i find model number
Kenmore 70 series dryer won't heat up
  • 55 Answers
Its most likely your heat sensor. if you get behind your dryer you will see a panel thats held on by screws remove that and you will see the sensor which has two wires going to it, you can just clip those wires and wire them together.and that will bypass the sensor.not the professional way but the cheap way.
Posted on Nov 26, 2008
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Need to know how much heating coil cost on my 70 series kenmore extra capacity dryer.
open dryer door and get model # 3 numbers a period and 6 more #s, they varry in price from $30.00 to $100.00
Dec 09, 2009 | Kenmore Dryers
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
254 people viewed this question
Top Dryers Experts
