Question about Mitsubishi WT-46807 46" Rear Projection Television
Color gets distorted and picture is narrower
These things happen every so often then when to tap the television a little and it goes back to normal
  • 905 Answers
There is a bad solder connection that needs investigating
Posted on Nov 26, 2008
Tv picture distorted
Depending on how long it has been used. Many a times the problem is caused with DJs or simply dry joints what I normally do is open the panel in a clean environment then switch it on make sure the picture is on then with the back of a screw driver tap gently on the ddc card if you see pictures coming back to normal and off again you have your culprit go ahead and solder carefully the dry joints on the ddc card ddc stands for data display channel
Mar 29, 2014 | Samsung LN46A650 46 in. LCD HDTV
According to the description, the color wheel went out. Loud humming noise, color distortion. I got a color wheel and first, by mistake opened the back of the screen, tilted it out a little way and...
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
Aug 08, 2011 | Samsung HL-R5668W 56" HDTV
Recently moved TV up stairs and afterward had a blue bow and double images. After a few hours i tried tv again and picture was almost normal again. it still has a little distortion but almost normal. what...
To get it absolutely back to normal you would have to remove the casing and re-align the inner workings. The only other option would be to go to your menu and adjust the settings, to return color and images to as close to normal options.
Mar 02, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Picture goes out periodically
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Sep 24, 2007 | Sony KP-61S75 TV
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Tv has wavey pic in center (random every 4 minutes)
Im sorry i dont quit understand the complaint.. Can you post a picture of this problem I have workeed alot on maggys.
Sep 18, 2006 | Philips Magnavox 27MS343S 27" TV
Mitsubishi WT-46807 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
