I have an Anchor, Liberty PA speaker that shuts off when I speak on the mic or as sson as I raise the volume. What is the problem?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your concern would be indicating two (2) possibilities:
  • speaker impedance mismatch. For some reason, the output thinks that the speakers connected to it are too low. This could be brought about if several speakers are connected to a single output without proper matching;
  • electronic/circuitry problem. the amplifier has partial short or cold solder connections of faulty components.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 26, 2008
Everything works fine in my mps4500 system except if I speak to the microphone too loud, it will result the speak power off. How to fix it?
I don't have a fix for this mine does the same thing I turn on and speak and it turns off then I have to turn back on.does battery need replaced or will it play with just the ac plug.
Dec 08, 2013 | Anchor Audio/PA Systems: Liberty Sound...
Acer aspire one d255e mic not working on pc
I need to connect my microphone to my computer can you help me please
Sep 07, 2013 | Anchor Audio/PA Systems: Liberty Sound...
How to open anchor audio liberty speaker system
As I remember the Anchor has a removable metal back plate that is used to mount the volume control and 1/4" or XLR connectors. Before you start disassembling the unit....are you a qualified repair person? Other than a bad speaker, broken wire or connector there's not much "user servicable" parts inside.
Feb 16, 2013 | Anchor Audio/PA Systems: Liberty Sound...
Not a microphone problem.. my friends Anchor Audio Inc. LIBERTY self contained sound system has no output. when power is turned on I hear a little pop in speakers, so I assume they are ok. usually...
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them from, and they have online it
was very good manual. Go ahead, I bet.
Mar 05, 2018 | Anchor Audio/PA Systems: Liberty Sound...
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
I have a Liberty 4500. Hum Noise when cable is pluged in
You don't say what's at the other end of that cable. It's a player in this scenario, too.
Feb 08, 2010 | Anchor Audio/PA Systems: Liberty Sound...
How do you replace a battery in an Anchor Liberty 4500 PA system?
Here is the link to the manual if you don't have one:http://www.google.com/search?hl=en&q=Anchor+Liberty+4500+PA+system+battery+power+replacement&btnG=Search&aq=f&oq=&aqi= It appears as if you have to remove the entire control panel to replace the two batteries. You probably have to use exact replacements. THe link to the company is in the manual and they can probably give you more information. Hope this helps.
Nov 26, 2009 | Anchor Audio/PA Systems: Liberty Sound...
My speaker is not working and looking in the box I did not receive a user's guide can I get one to check why the speaker is not working. Thanking you advance, Pauline Sangiacomo 87 Saylor Rd Schwenksville,...
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} You do not say what computer you have or what your OS is
We will go with Laptop & Vista
TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab.
You have 2 mics on display -you want logitech as default ( green check mark )
Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph display.
Aug 12, 2009 | Logitech Computers & Internet
 Grubhead
Grubhead
