Question about Toshiba Computers & Internet
The laptop will not start... it does not hold its charge and when the charger is in it still does not respond. it flashes an orange light at the battery light but nothing else happens. i have taken out the battery then connected external power and still no respond?
    Problem Solver:
  • 13 Answers
You may need to replace the battery. The battery is not holding charge so it is likely bad; but worse, it may be overloading the supply and keeping the unit from starting. Some supplies will not operate without a battery in place. If it worked previously, then you are fairly safe in the battery investment. If you don't know if it works, you will have to decide, as a starting with a fresh battery may still uncover other problems.
Posted on Nov 26, 2008
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
Battery icon flashing orange
Sorry to here about your problem with the orange flashing light.
1st. You really are not giving enough information to identify your problem.
2nd. If your battery is charging when unit is turned off and you can see a blue charging light on the front left panel, that's good but should only charge for 1 or 1 1/2 hrs. max.
3rd. If your charger is getting to hot to hold while attempting to charge the battery, you may have a bad battery.
4th. If the orange light disappears after removing the battery and replacing it with a known good battery, its the battery.
This unit is an HP and HP has a recall on many battey's. ( I have worked on al least 25 HP Laptops and in two years have not found a battery to return under recall ) Thanks, HP !!!
All and All, it sounds like the battery is NFG.
Drop me a email or reply here as to what you have found.
John Ray
Jun 22, 2009 | Dell Inspiron 6000 Notebook
Not able to hold a charge and orange light flashes
as an EX dell tech your battery is dying
just get another battery
Apr 10, 2009 | Dell Latitude 120L Notebook
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Dell D600 Doesn't switch on
check to see if the charger has current flowing. maybe the charger not charging the battery.
get hold of a voltage tester hold the black end on the outter round part stick the rred end in the middle place it on the male prong you should get a 19v reading.anything like 14v 10v or loweer can charge the battery.if you get a19v 18.blah v reading then you need a motherboard repair or replacement
if so get one cheap on ebay
inspiron d600 motherboard
Apr 16, 2008 | Toshiba Tecra A5-S416 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
