Question about Garmin nuvi 205 GPS Receiver
Connecting car charger puts it into PC mode
I find that I have to keep the Nuvi 205 on for some time (and it must be in navigating a route) before conecting the car charger, otherwise if I connect the charger before turning the unit on, the PC connection mode stays on until I unplug the charger and turn off the unit.
Any help?
  • shoppingirl Dec 29, 2008
    Everytime I plug my Nuvi 205 into my car charger, it puts it into PC mode and displays an icon that it is connected to the PC.
    I can shut it off and reset it and drive for a while, but it ends up happening again.
    I don't even have a cable to connect to my PC
  • Anonymous May 15, 2009
    Exactly as described above. Charger is useless for what I require.
    Help!!
hemantraj
  • 638 Answers
SOURCE: nuvi 205 dead
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Posted on Dec 08, 2008
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
SOURCE: my garmin nuvi 205 quit talking
I have a 750. I went to settings, language and restored the defaults. The Voice was blank when I went to that screen. I am not sure if the 205 has the language setup or not, but this should solve other Garmin problems. And as a bonus, if you want to solve the problems with the US, Fire Congress check out http://FireCongress.org
Posted on Mar 05, 2009
SOURCE: I have a nuvi 200 that wont run when it is hooked up to a power supply
Vehicle Power Cable to the nüvi and connect the otchapin.screen1.jpgher end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart chapin.screen2.jpg(reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging."
Posted on Mar 15, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
Any time I plug my Nuvi 205 into my car charger, it shows that it is in pc link mode. How do I get my Nuvi 205 to get out of pc link mode while it is plugged into my car? It renders the GPS useless as it...
Sometimes this problem is caused by the charger plug not going far enough into the mini usb socket of the satnav. It feels as if it's fully in but it's not. Pushing it in further usually solves the problem. As your charger is not a garmin make there's no guarantee but there should be very little difference so it's worth a try.
Mar 08, 2011 | Garmin nuvi 205 GPS Receiver
How do i save routes to adrsses i have put in
I'm sorry, but the nuvi 205 doesn't retain route information. You can save your destination as a "favorite," though, and let it recompute the route from wherever you happen to be.
Apr 15, 2010 | Garmin nuvi 205W GPS Receiver
My Garmin nuvi 205 keeps saying it is connected to the computer when it is plugged into my car charger. It worked great until the original charger broke and I had to buy a new one. Now this charger...
When your Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Mar 06, 2010 | Garmin nuvi 205 GPS Receiver
My nuvi shut off and does not want to come back on
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
I hope that helps.
Jan 26, 2010 | Garmin nuvi 205 GPS Receiver
I'M A TRUCK DRIVER AND MY WIFE BOUGHT ME THE GARMIN NUVI 205 W BUT IT DOES'NT HAVE TRUCK ROUTING IS THERE A WAY I CAN DOWNLOAD TRUCK ROUTES INTO MY GARMIN???? PLEASE HELP
Unfortunately i dont think you can as this unit is set up for car navigation, but try Garmin support and maybe they have a solution to your problem, happy new year mate good luck, Colin.
Jan 04, 2010 | Garmin nuvi 200W GPS Receiver
My nuvi 760 routes me the long way around
You should do the following: Changing the Navigation Settings;
Touch Tools>settings>Navigation. There you'll find how the sysytem will calculate your route.Route Preference.........Faster Time....Shorter Distance.......Off Road....Avoidances,very helpfull....Restore original navigation settings.
Hope this will help you,
JADF
Mar 24, 2009 | Garmin Nuvi 760 Car GPS Receiver
My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
Mar 19, 2009 | Garmin nuvi 205 GPS Receiver
When i plug my car charger to my GPS it turns it to PC mode and im not able to use my GPS while its charging.
Here is a nice trick to use the Garmin while charging with a USB cord or a wall charger: with the Garmin unplugged keep your finger on the battery icon for about 10 seconds until the diagnostic screen comes up. Then connect the USB cord and press EXIT; the Garmin will reboot and you will be able to use it normally.
Jan 22, 2009 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
769 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
