Question about Hitachi 53UDX10B 53" Rear Projection Television
BLUE BULB CONVERGENCE
CAN MOVE LEFT TO RIGHT BUT NOT UP AND DOWN! HOW DO I FIX IT? TV WORKS GREAT 1996
  • Anonymous Nov 28, 2008
    when trying to convergence can move left to right but not up or down with the cursor ? Need to line red and blue over the green, but it will not let me do it. What am I doing wrong ?
  • Hitachi Master
  • 8,617 Answers
Replace the convergence ICs and feed resistors. You can get replacement ICs and resistors at the following link with installation instructions. If you leave them a email with your model number they will tell you the correct ICs and resistors for your model set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Nov 26, 2008
Our tv looks like a 3d tv. Out of focus
Try to adjust the convergence using the original remote control of your tv, then go to the convergence setting menu, then go to convergence section. You should be able to move the blue and red in any directions right, left and up, down. Or if you cannot move them far enough the convergence chip is defective replacing the bad convergence chip will fix the problem. Feel free to send feed back good day and best regards.
Aug 21, 2011 | RCA Televison & Video
PHILIPS 60PP9202/17F - Left/Right convergence doesn't work for Red/Green or Blue. Up/Down convergence works OK - What might be the problem?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 17, 2010 | Philips 60PP9202 60" Rear Projection...
Upper left corner is distorted and neon green
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Sep 14, 2009 | RCA HD52W58 52" TV
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Tv has a the blue tint that won't line up.
the problem is with the convergence, 1 or more chips could be faulty. replacement is the oly option if faulty stk-xxx-xxx
Dec 26, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Blue convergence wont align left and right
I'm having the same issue but with Green. Check out this guys blog he had a similar problem and fixed it.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
Nov 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Blue Convergence Problem
This is a pain and you have to be carful in doing this fix. Its basically the bulb thats shot, its got that liquid in it so DO NOT BUST IT OR YOU WILL SCREW THE BOARD UP! THen you have to get a new TV
Oct 26, 2007 | Philips 46PP9302 46" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
