Question about Kenmore 62802 Electric Dryer
Something in vent
My wife was doing laundry and cleaning out the lint vent when a fairly large piece of cardboard fell down the vent. This creates a fire hazzard. How can I get it out? It's a Kennmore 80 series electric.
    Genius:
  • 1,028 Answers
Id screen is on top remove the 2 screws under screen lid remove back cover ..remove the 4 screws holding bottom portion of screen housing over blower pull out and clean ..if screen is in door remove bottom cover (clips top edge press down) remove lint screen remove 2 or 3 screws holding housing to blower
Posted on Nov 26, 2008
There is a piece of cardboard inside covering a metal panel, do I need to remove it?
Interior of microwave ovens are metal, never cardboard. Must be something used for shipping purposes, pitch it.
Jun 17, 2015 | Microwave Ovens
My neptune dryer seems to be overheating. It's very hot to touch the outside unit and is heating up my laundry room. The vents are attached and the lint screen is clean. What is the problem?
Hi twokids90s
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 20, 2011 | Maytag Dryers
41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
Apr 19, 2010 | Kenmore 62802 Electric Dryer
A clothes pin and piece of paper fell down the lint trap when I was cleaning the screen. How do I reach the pin and paper to get them out?
This may take you awhile to do, but once you get to it you may find a lot more than that down there. You have to remove the back on most all dryers. If the lint trap is on top, there is a metal chute that lint and other objects fall down.Remove the back and you will see what I am talking about.Once this is done, it is fairly easy to remove the collars that go down to the lint hose. You will then be able to clean all of the lint build up down below that gets by the trap.
Good luck, Sincerely, shastalaker7
Oct 30, 2009 | Dryers
Taking to long to dry
  1. Separate heavy weight items from light weight items when creating loads. Heavy fabrics take longer to dry because they tend to retain more moisture. To help reduce and maintain more consistent drying times for large and heavy fabrics, separate these items into smaller loads of a consistent size.
  2. Use the appropriate control settings for the type of load you are drying.
  3. Please confirm that the lint filter is clean prior to each new load of laundry.
  4. Divide your larger load into a number of smaller loads.
  5. If you are only drying a handful of items, add a few extra pieces to help ensure proper tumbling action.
  6. Confirm that the exhaust venting ductwork is properly configured. Confirm that the venting is free of obstructions. Confirm that the outside wall dampers are moving freely, that the dampers are not pushed in, and that nothing has been set against the dampers.
Oct 27, 2009 | Maytag Dryers
We have a lg dryer and it takes very long to dry clothes, I have checked out the vents and still does the the same,please give advise thank you
Oct 23, 2009 | LG DLG5988 Gas Dryer
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Sponge fell into lint trap. Is there something I can buy to put down the lint trap to try and get it out?
Surely you should be able to remove lint trap, or you would not be able to clean it!!!!.
Otherwise try a piece of wire with a hook on the end , and retrieve it that way.
Dec 15, 2008 | Dryers
My Miele T8322 Tumble dryer turns off before the clothes its fully dry even in Extra Dry mode. The vent pipe is clear. Is there any kind of adjustment or do I need to get a new sensor under warranty...
IS THE DRYER PUSHED UP AGAINST THE VENTING IN THE BACK OF THE DRYER? IT MAY BE CRIMPING THE EXHAUST MATERIAL CAUSING A RESTRICTION.
IF THAT IS O.K., DISCONNECT THE EXHAUST AND RUN A LOAD OF LAUNDRY THROUGH A NORMAL DRY CYCLE.
IF THE DRYER DRIES THAT LOAD O.K., THERE IS A RESTRICTION SOMEWHERE IN THE EXHAUST. ALSO, CHECK THE LINT TRAP. IF THERE IS A WHITE CLOUDY FILM ON THE LINT FILTER, TAKE A WIRE BRUSH AND CLEAN IT OFF. IT IS RESTRICTING THE AIR FLOW AT THE FILTER.
CHECK THE LINT FILTER HOUSING FOR A BUILD UP OF LINT. IF THERE IS, USE A CENTER CARDBOARD FROM WRAPPING PAPER ATTACHED TO THE END OF THE VACUUM HOSE. FLATTEN THE CARDBOARD TO FIT INTO THE FILTER SLOT AND CLEAN OUT THE LINT.
Apr 22, 2008 | Dryers
I put laundry soap in the dryer by accident
DO NOT pour water down the lint filter of a dryer! This could have catastrophic results. There are live voltages present in a dryer even with the power shut off. You have a blower fan and a motor in the air baffle. Pouring water in there will definitely damage something (if the soap hasn't already). Detergent is a corrosive and will damage anything electrical and any painted surface if left too long. I hate to say it, but you must open the dryer up and remove the air baffle and clean it out thoroughly. Unplug the machine before you attempt. You need to wipe up all the soap residue with rags. You will need to let me know if the dryer has a lint filter on the top of the machine, or in the door before I can suggest how to disassemble. This will make a big difference in the amount of effort required to correct this. Post me back with the info...
Aug 08, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62802 Electric Dryer Logo
156 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
