Question about Compaq Presario 5000 PC Desktop
D:\ directory name invalid message
When I try to run a CD I always get the error message of D:\ directory invalid
  • Howard Lester May 11, 2010
    It sounds like your cd may have a different drive letter other than D. Is that possible? If so I will let you know what to do to fix it.
    Problem Solver:
  • 5 Answers
That error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
Posted on Nov 26, 2008
Rw 240 scantool, gives the following error message:Could not create directory ...The filemane, directory, or volume label syntax is incorrect.This is my first time using this plotter/scannerRicoh RW 2
Check the folder name & location of the directory at the end of the error message string, then check to see if that directory actually exists and if you (logged in user) actually have full read/write privileges to that directory.
May 08, 2014 | Ricoh - RW-240 Print Controller - 411737
Error messages: translators were not loaded due to errors on Dreamweaver8
Dear Sir,
the only solution to this , logon with administration user and reinstall the software in differnt directory , I REPEAT IN DIFFERENT DIRECTORY. select custom settings and change directory
thanks
Gizmo
Dec 19, 2007 | Computers & Internet
The directory name c:\user\nimra\local\application data\google\chrome\default is in valid please help me how i can remove this problem
I would recommend uninstalling it and when asked remove user data as well and reinstall chrome. The default user profile has become invalid.
Oct 10, 2012 | Dell Computers & Internet
Unable to open downloads
I'd say, offhand, that you are looking in the wrong place for the stuff you downloaded. Otherwise, Windows would try to open it and if it couldn't, you'd get an error message.
Try this: What I always suggest to my clients is to create a directory called something like "download" under the root directory (e.g. c:\download) Save your files to that directory. The system should remember this and always save there.
Now all you have to do it go to that directory and you'll be able to see the files and run them.
Sep 27, 2009 | Compaq Presario 5000 PC Desktop
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
AGV 8 (build 233) Installation
Make sure all other antivirus software is removed before you try to install it.
Also, run a scan for existing infections with an online scan like TrendMicro = http://housecall.trendmicro.com or
Panda http://www.pandasecurity.com/activescan/index/?track=1&Lang=en-US&IdPais=63
Feb 03, 2009 | Microsoft Windows XP Home Edition
If D drive is a cd/dvd then the issue is a format issue as those media have length and path constraints. If this is a secondary hard drive then right click on the drive icon in My Computer to see the Properties. Post back after you do thiswith the directory name and I will help you determine the problem or if there is a real problem as some directories create by Windows are for system use. You can rename the directory if it is a hard drive but please post what it is before you do that. Steve Medley
Nov 26, 2008 | Computers & Internet
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
MS Office 2007
First uninstall the MS Office 2007 on your system, then go to the target folder directory where you just installed the Office2007, its usually under PROGRAM FILES folder, and locate the right folder (usually named as "Microsoft Office") and DELETE manually this folder.
Second, restart your computer, then try to re-install the Office 2007 again.
I hope this procedure works.
-mrsolution
Jun 11, 2008 | Microsoft Office Professional 2007 Full...
Compaq Presario 5000 PC Desktop Logo
137 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
