Question about Panasonic CQ-C9800U CD Player
Panasonic CQ-C9800/C9700 Had bought this unit some time ago and installed properly in car. The unit power jumps in and out. Each time it does it is for an indefinite period. It is not the saftey feature cause power goes on and off 2 ways ( 1st-standard 2nd-unit completely resets) Have check fuse? checks OK Have checked power (red) connection. check OK Have checked ground (black). check OK Not sure what to do next? Any help would be great...Thanks David S
SOURCE: Panasonic CQ-VD5505W dbl-Din dvd 7'' touch screen CAR AUDIO
I HAVE THE SAME UNIT AND UNTIL YOU HOOK UP THE HANDBRAKE CABLE THE UNIT WILL ONLY PLAY MUSIC
Posted on Jan 07, 2008
murdozzz2
  • 75 Answers
SOURCE: panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Posted on May 02, 2008
  • 28 Answers
SOURCE: How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Posted on Mar 25, 2009
  • 9 Answers
SOURCE: just need to know which wire goes where
orange is normally illumination(not necessary) other is probably cell phone mute
Posted on Jun 12, 2009
  • 43 Answers
SOURCE: my car radio has to be reset every time the car turns off
i don't know what kind of car that you have but on that radio there should be two power wires one is red and the other is yellow,the red wire connects to the wire in the car that will only have power when the key is turned to the on position,the yellow wire connects to the wire in the car that always has power with the key off.........
Posted on Jul 01, 2009
The unit worked fine for a long time. a few days ago i changed cds and when i put the cd in it sounds like it is spinning and then nothing and it ejects the cd..the radio still works on the unit. I just...
Some Panasonic stereo's don't like non shop bought, home burnt discs (they are recorded at a different level) so try new discs plus run a CD laser cleaner through your system.
Jul 12, 2011 | Panasonic CQ-C1101U CD Player
Set time car radio/cd Panasonic CQ-C13367
First of all, go to service.us.panasonic.com/operman to get the manual for your unit.
With the unit turned on and the clock displayed, pres disp for more than two seconds. The hours will blink... press < or > to adjust hour. Press disp again, the minutes will blink... press < or > to adjust minutes. Lastly, press disp to store the correct time. Good Luck!!!
Nov 09, 2010 | Panasonic Car radio CD CQ-C1110GN CD...
How do I get the ID code on a Panasonic CQ-VD7003...
I have the same unit if you hold the right round stick knob to the right for 10 seconds while the unit is on it should unlock the unit if the previous owner didnt set a 4 digit code. I had the same problem and it worked good luck.
May 18, 2010 | Car Audio & Video
I ned code for panasonic cq-vx100u the mecanic desconect the bate
bought car yesterday they changed the battery and now there is a code display that has the unit locked up
Jun 05, 2009 | Panasonic CQ-VX100U Car DVD Player
NEEDING A WIREING HARNESS TO INSTALL MY CQ-DP102U PANASONIC. THANK YOU
You can check out the parts available from Panasonic at thier web site - here's the page with the parts list that are still available: http://www.pasc.panasonic.com/Epartr/PartsList.asp If you don't want to do that - I'll buy the unit at a reasonable price. The unit in my motor home that I just bought doesn't work and the wiring harness is integral to the dash wiring harness since it was factory installed so I want to replace the unit with an identical unit. eMail: Gene-Bostwick@Comcast.net
Nov 05, 2008 | Panasonic CQ-DP102U CD Player
Panasonic cdplayer Model CQ-C5310U
Yes the hook is the round port on the top right side of the back of the unit right above the main hook ins for power, ground, and speakers.
May 21, 2008 | Panasonic CQ-C5310U CD Player
No sound from CQ-1305U car CD/stereo
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Dec 25, 2007 | Panasonic CQ-DP383U CD Player
i got the same problem and i ground the green/white to the case of the unit. do i have to ground it to the chassis?
Dec 04, 2007 | Panasonic CQ-Vd7001U
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
Panasonic CQ-C9800U CD Player Logo
67 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
