Question about PfaFF Hobby 4260
Reverse stitch lever broken
How do I replace the reverse stitch lever on a PFAAF hobby 1142?
  • Anonymous Dec 07, 2008
    Pfaff 1142 also with broken reverse stitch lever! First "repair" shop charged me $60 to clean machine (I had JUST done it), and told me it was "tilted" to the side on purpose NOT!... Second shop ordered the part in JULY and I'm still waiting for it to come in with no time frame from them :-( Best of luck to you - Take it to a Pfaff dealer so maybe they can get the part AND fix it for you :-)
4 Suggested Answers
  • 323 Answers
SOURCE: Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
Posted on Jul 01, 2008
I have the same problem. |Until I can get it fixed \i have been tipping it back to straight and then pressing down evenly which seems to give me a little reverse. I think that the plastic extension inside is cracked. \i hope that this is a part that is acessible!
Posted on Jan 10, 2009
robert-fell
  • 39 Answers
Hi, your reverse stitch lever is broken, it's plastic and should have been made stronger. Pfaff doesn't make it easy to get the front half of the plastic case off, which you will need to do to get to the lever. I haven't found anyone selling a replacement part. You can go my route and try a repair with epoxy.
Posted on Apr 21, 2015
My heavy duty Singer sewing machine is stuck in reverse. How do I fix it?
If this machine has a mechanical lever or button it may be internal parts have broken and need to be replaced. this is a common issue with lots of machines. The machine breaks when in reverse and will only sew in reverse. Please have a professional look at the machine and make a repair if necessary.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Singer Sewing Machines
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
Is there a reverse switch? where
Depends on your machine. Consult your owner's manual.
On a lot of older machines, the Stitch Length Selector will reverse if the lever is pushed all the way up. Some really old machines do not have a reverse, so what you have to do is sink the needle in the fabric, lift the presser foot, and swivel the fabric 180 degrees so you can stitch back over the previous stitches.
Newer computerized machines will have a button, lever, or switch sometimes labeled with a reverse arrow.
Jul 15, 2015 | Sewing Machines
How to fix sewing reverse
try to pull the fabric as you hold the reverse lever.....pull away from front towards yourself. the dogs pull the fabric in the opposite direction. make sure your stitch length is narrow or "1" ...reverse only works with a straight stitch foot not a zigzag. Sometimes a machine needs a little help getting the reverse mechanism going......
Feb 12, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
My machine will not reverse stitch. What can I do?
when you try the reverse stitch lever or knob and it doesn't respond then the machine needs to be checked to see if there is a broken part.
Mar 20, 2014 | New Home MX-3123 Computerized Sewing...
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Is there a reverse stitch button on singer 457
On the right is a lever .. Bottom has numbers .. Mid says "fine" .. Move that lever up to the top for reverse
May 08, 2010 | Singer 3116 Simple
sewman7
Jul 01, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
95 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
