In July my old HP Pavillion power supply unit died, so I purchased a new Compaq presario desktop. I just had the power supply unit replaced in my old system so I could get to my old files. I had purchased a Seagate Freeagent 500GB external hard drive to put the old files on, which was done successfully. I now have the external hooked up to my new system but I can't get it to install and then run to be a back up for my new system? Will it now allow me install and run on the 2nd system?
    Sergeant:
  • 306 Answers
If this is a usb external drive then it will be shown as a removable drive in My Computer. Just right click on the icon>Explore and you should be able to view the files on that drive. If you do not see a removable drive then please post back and I will help you determine the problem. Steve Medley
Posted on Nov 26, 2008
How do I replace the power supply, and can I use one from an SR1738NX?
Before attempting to replace the power supply, I would check to see if they are compatible. I would check to see that the wattage of the Compaq Presario SR1738NX is the same or larger than what is in your current computer. This information should be on the label of each power supply.
Next, I would check the connectors to ensure that all the connectors that are currently connected exist on the old power supply.
Next, take pictures of all the power supply connections on your new machine.
Finally, remove the power supply from your new computer, replace it with the power supply of your old computer, reconnect all of the connectors, and turn on the machine.
Good luck,
Paul
Dec 21, 2015 | HP Compaq Presario SR1910NX (EX310AA) PC...
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
May 14, 2014 | HP Compaq Presario SR5450F Desktop PC
Whats wrong with a compaq presario sr1711nx when the front light blinks green and has no power?
Could be the internal coin sized battery is dead or dying.
Could be the power supply has failed.
Apr 08, 2011 | HP Compaq Presario SR1711nx-b (EL428AA) PC...
Compaq presario desktop sr1503wm fan at rear of cpu box won't turn. can it be fixed or replaced? apparently the other fan is overworking and causing a loud buzzing which goes off and on again every few...
If it is the fan in the power supply, replace the power supply.
The case fan is easily replaced. Measure it (in mm) and purchase a new one. The standard fan is usually 40 mm, I think.
Oct 07, 2010 | HP Compaq Presario SR1503wm PC Desktop
Compaq Presario SR1265CL replacement power supply
You can replace power supply the higher wattage the better.
Mar 21, 2010 | HP Compaq Presario SR1265CL-B...
Not sure about upgrading power supply
In many cases the additional 4 pin section slides up and off of the main power plug for use in your particular unit.
Feb 20, 2009 | HP COMPAQ Presario SR5410F Pentium...
Wont stay powered up
plz check with a new power unit if the problem remains then *********** board needs servicing
Jan 13, 2009 | Compaq Presario S5100NX (E120866) PC...
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
A new motherboard for a old compaq presario 5240
You will need a new case and a new power supply. I would replace the memory as well.
Compaq had a tendency to make cases to only fit their boards back then. Youre better off building a new unit and starting over again.
Jun 14, 2008 | Compaq Presario 5240 (353200-003) PC...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
