Question about Kitchen Ranges
I have a gas Tappan stove with an electronic ignition. How can I light the oven manually?
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Yo cannont light manually if it requires a glow bar,sorry, no way to bypass.
Posted on Nov 27, 2008
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
158 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
