Question about Pioneer AVH-P6500DVD Car DVD Player
Opening and closing
How can I find a detailed parts list? The screen won't slide in and out. I have found a broken bracket and stripped gears and need to find the parts to replace them.
  • 752 Answers
I don't know if they sell to the general public but try www.pacparts.com. They carry a full line of Pioneer parts.
Posted on Sep 11, 2007
How do you reset sunroof in a 2001 Monte Carlo with 3400 model I
check fuse and relay if good than possible motor ot track problem their should be a mechanical bypass that will let you close it if stuck open the following information is courtesy of monte carlo forum
To check the condition of your original sunroof guides:
  1. Gl*** in closed position.
  2. Locate & remove 3 torx bolts on each side of sunroof glass. Lift glass out of sunroof opening & set aside in a safe place.
  3. Locate "J" shaped cover plate at front of sunroof track assembly. Remove 2 torx bolts from each cover plate.
  4. Lift up bracket to remove.
  5. Inspect the plastic guides on each side. The sunroof cables attach to guides on front outer corner. Inspect this area closely for damage.
  6. Do not operate the sunroof with the J plates removed.
Troubleshooting:
If the sunroof guides are not broken & the glass is a uniform height along the rear edge your problem may be a stripped gear inside the motor. The motor has a manual override:
  1. Get access to the motor by removing the map light/switch console or lowering the front of the headliner.
  2. Insert a large standard screwdriver into the nylon bushing at the center of the motor hub. Push up & turn the screwdriver to manually move the sunroof glass. If the unit will fully open & close manually, you most likely only need a replacement motor.
If your sunroof is stuck in the open position follow these steps to get it closed:
  1. Remove the glass.
  2. Try to close the unit without the glass. Many times one side will still be operational and close correctly.
  3. Try to slide the inoperable lift arm forward. If it moves, slide it forward until it stops.
  4. You now need to slide the original plastic guide forward to lower the arm to the closed position. Using a standard screwdriver, push it forward. The lift arm should begin to lower.
  5. If the lift arm will still not fully lower, remove the J plate as explained above, sometimes the sunroof cable will need to be lifted up to allow the guide to fully slide forward.
  6. Reinstall glass.
May 21, 2016 | Cars & Trucks
Bevel gears are worn
Most common repair for this saw
1) remove blade & blade housing guard plate
2) You will find 2 allen head screws holding the elevating screw bracket
This will allow you to move the gears apart to replace
Remove the small retaining ring and slide the gear off (be careful not to lose the woodruff key when you slide the gear off)
Typically we find that the 2 rods (elevating shafts) are bent and this causes the resistance that strips the gears out - I always replace the 2 rods and the elevating screw when replacing the gears - you already have it apart and the parts are inexpensive.
Aug 31, 2013 | Dewalt Saws
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
I have a Craftsman garage door opener, model# 13953674srt1. It will not open or close the door. The motor sounds normal & runs the entire cycle but the chain is not moving. What is the problem?
Remove the cover from the motor unit and you will find the drive gear is stripped. The part number is 41A2817 and is available at any good door service company.
Jan 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The DVD door only closes part way because it is hitting the part with the laser that slides forward and lifts to match the spinner on the top of the frame. I think it is supposed to slide over it before...
I twisted and pried until I got the door/disk carrier out of the case. It appears the the teeth on the left side of the door and the teeth on the gear that moved it as well as a white strip of plastic with an upright pin and teeth on the front edge which moved it from left to right were out of sequence. The strip was moving too soon and causing the motor and laser to lift before the disk was in place. The disk carrier was blocked by the spin mechanism which had raised and was up against the piece that the disk should be under.
To fix it, I set the DVD player to "open". Then I put a long narrow strip of masking tape on one side of the teeth of the gear that was supposed to open and close the door.
I pushed the moving strip with the pin as far to the left as it would go and put another narrow strip of tape on the top of it to keep it from moving while I pushed the door back in place. The ends of both pieces of tape extended out the opening and were stuck to the face of the cabinet.
I pushed the door into the frame, pulling up a bit in the center to get it to go through the guides and track. When I got it pushed all the way in I started easing the tape off the gear, pulling on the part outside the door and reaching through the hole where a disk would set to loosen the end of the tape on the gear with a mini screwdriver. I did the same thing with the tape I had put on the strip with the pin.
Then I used the "open/close" function to test it and it worked like a charm. The door guides do not hold the very tight and it tends to wiggle and lean to the left when open.
I also found a really good video by a guy on UTube. It was not my brand of player, but his explanation and demonstration gave me enough info about how to get the door out, without destroying it, so I went at it.
My methods are a little unorthodox, but they worked without tearing the entire thing apart. I couldn't figure out how to get the motor/laser out anyway.
Good luck with yours.
Jan 02, 2010 | Daewoo Televison & Video
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Stripped gear
Try opening and closing your door by hand with the motor detached (detach it by pulling on the rope) It should open and close easily without a lot of effort. If it catches or is too heavy (possible broken spring) it will strip the gear. The door has to be working properly before you can attach an opener to it. If you lift your door up about waist high and let go of it . It should not go up or down but should stay in that position, This tells you that the springs are correctly adjusted
Feb 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to replace carriage on stanley sd450 opener how is it done?
Please make sure you don't have broken springs first and that the door is balanced properly. If so you can replace the "Trolly" by disconnecting the arm from the opener, undoing the opener from the bracket that mounts it to the wall. This usually takes a 1/2 in wrench. Then swing the opener out far enough to slide the trolly off and replace it with a new one. Re-connect everything then re-engage the trolly.
Oct 25, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
How to get to mirror and lenses on a pioneer SD-643HD5?
unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Oct 18, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer AVH-P6500DVD Car DVD Player Logo
95 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
