Question about Dell PowerEdge 6400 Server
I opened and cleaned most of the inside of my Poweredge 6400 server. When I fired it back up, everything worked except that two of the three power supplies are not running. The middle bay is still functional. Any of the three power supplies placed in the middle bay work but none of them will work in either the left or right bays. They were all working before I cleaned the system. Any ideas?
    Problem Solver:
  • 16 Answers
I'd suggest removing the power supplies and giving it another blow out to make sure there's no dust that's insulating the contacts from connecting properly in the other 2 bays. Also check behind them that all cables are connected properly (if it's going to a power circuit board) as one of them may have been knocked.
Posted on Dec 15, 2008
When i press start button of dell poweredge 2900.the server display the dell logo for a long time.nothing to ahead and hang. whats the solution.
open the system and remove the ram clean the ram pins with an eraser and fix back. check if it works.
normally this happens due to ram connection or bad ram which needs replacement
Aug 30, 2012 | Dell POWEREDGE 2900 Server
DELL POWEREDGE 6400 IS NOT BOOTING FROM THE CD
Go to your BIOS and change the boot sequence so that the system boots to the CD 1st. (You should see a tab or label that says Boot Order or Boot Device.)
Good Luck
C2S
Aug 13, 2010 | Dell PowerEdge 6400 Server
It makes unexpectedly restart
This server should never restart as you describe
1: Turn off remove all 3 power supplies clean, replace
2: Clean the insides removes and reset each add-on card’
3: Remove each of the SCSCI drive from the front “DONOT MIX” up makes sure each drive returns to the same place as removed if not raid will be broken.
4: Check the UPS Power backup this sounds like you are running direct not on a UPS battery backup if so then replace the power strip with 20 amp. The wall outlet should also be 20 amp circuit barkers
5: After you have clean the server check to be sure all three power supplies are showing “GREEN” lights
The most common problem causing instant restart on this server is loose or poor connections it is possible you may have a” virus”?
From what little I know poor line power is causing your problem too many devices connected to the same wall out let may not Trip a barker yet will cause recycle of the server.
Memo:
If you must operate this server not on a UPS Battery backup then make sure one power supply is on a different circuit, meening on a separate barker in service panel .I hope this will help solve you problem.
Nov 15, 2009 | Dell PowerEdge 6400 Server
DELL PowerEdge 1600sc - New motherboard no joy
Are you sure the new motherboard was of the same revision as the old one? Dell shipped 400FSB boards during the beginning of the 1600SC line and shipped 533Mhz boards during the end of the run. I would check the revision level of the motherboard to make sure it is compatible. If it's the same revision, I would start small and connect just one CPU and put the system at 512mb ram and see if that works. If this works, you can begin to add additional components as needed.
Good luck
Jun 19, 2009 | Dell PowerEdge 1600SC Server
Where to plug power button into mother board
Open the case of the server, and look on the side panel that you removed. It should have all of the server options detailed right on the inside of the case for you.
May 22, 2009 | Dell PowerEdge 2500 Server
I was cleanning the power edge 1800 then when i
Check to make sure cables are firmly seated...sometimes when you're inside a box, you might jiggle a cable loose.
May 02, 2009 | Dell PowerEdge 1800 Server
A Dell PowerEdge Server will not start. The server goes through the boot sequence, but after a while there is no activity. OS: Windows 2000 server
This sounds like a RAM issue or a strange peripheral problem (when the driver loads it kills the system). Try running the system on only 1 stick of RAM at a time, swapping until you find a bad stick. Also, clean the contacts off with a pencil eraser before putting them in.
If this doesn't help, pull PCI cards one by one (except for the RAID card, if any - but do pull out, clean and put back in the RAID card just in case it's a contact issue) at a time until the system boots (or just try safe mode, but this won't tell you which one is a problem).
If the system still can't boot, then I'd say it's probably the motherboard.
Jan 06, 2009 | Dell PowerEdge 2600 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Power
Most likey the PSU is dead, or fuse on the plug socket.
Jun 26, 2008 | Dell PowerEdge 1800 Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 6400 Server Logo
75 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
