It is by the model number a rear projection tube set--Look to see first if when a DVD etc is played you have color or not (via audio video jacks on rear of set)
If you do the set's color circuit is ok.
If using a box unplug it and wait--plug it back and let the box boot up.
If none of this helps the and the set has no color on all inputs you have some problem in the color or chroma circuit in this set---it is very rare for this to be a circuit problem.
SOURCE: Tv won't power up after power went out
Most likely your TV's power supply was damaged with the power surge. You will need to take it to a repair place and have the supply checked out and find out the cost versus the value of the TV. I hope this helps.
