Question about Frigidaire PLMV169DC Microwave Oven
Control panel went off and hence it stopped working
I bought and installed fridgidaire PLMV169DCD model 16months ago. Suddenly its control panel display went off. It came back once after I took out power and put it back but after couple of hrs it again went dead and never worked.
  • 1 more comment
  • vineshg Nov 28, 2008
    Yes. Its dead. No light and no beeps.
    Outlet is working fine. I tested the outlet other other appliance
  • s_fitz Feb 11, 2009
    Mine is dead too. I have a plmv169dcd. Problem is I cannot even locate a fuse. Is it a standard (tube-shaped) fuse or what. I've looked for something like a auto fuse too, but can't find one like that either. What am i missing? I've looked on the control panel board, on the floor and walls inside the oven cavity, behind the grate, in between the door switches. Nothing. What does it look like, please??? I don't want to send the unit out for repair without at least checking the fuse...
    Thanks,
    Sue
  • William Miller
    William Miller May 11, 2010
    Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad?
    Is the outlet working?
  • Frigidaire Master
  • 9,098 Answers
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Nov 28, 2008
My Frigidaire oven model PLMV169DCD has developed a defect
The only real issue with the control board that could cause that is a failing relay or bad connection, both of which I can repair on a control board for $54.95, which includes insured return shipping.
The first thing I would do is test the outlet. A toaster or hair dryer are good devices to use.
A microwave must be on its own breaker, or at least not on the same breaker as a high-current device (stove) or a device that causes spikes on the line (fridge, freezer).
It's possible you have a failing magnetron or high-voltage transformer, but I would need to discuss it to narrow it down.
For free additional DIY help and details, feel free to e-mail me directly from my site. Remind me of your full model number and detailed symptoms.
William E. ("Ed") Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 26, 2017 | Frigidaire PLMV169DC Microwave Oven
How do i remove a control panel on a fridgidaire microwave model # PLEB30M9ECE I don't SEE any way to get it off
Hello lisajwalls - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Since this is a complex unit, typically this is something that you want a certified professional to install for you to prevent any exposure to radiation, safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process
Nov 20, 2012 | Frigidaire FMV156DC Microwave Oven
How do I get to the control panel of my Frigidaire PLMV169DCD?
When you open the microwave door, on the right side should be two philips head screws. Unscrew those to remove plastic cover and there will be control panel behind which is secured with 4 screws.
Jan 05, 2010 | Whirlpool GH7145XF Microwave Oven
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Control pad does not repond
hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Mar 06, 2009 | Frigidaire PLMV169DC Microwave Oven
Plmv169dcd handle fell OFF
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
If you need more help with disassembly, we have similar service manuals and have uploaded them to our site here, here, and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Feb 13, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Microwave stopped working for no reason
A microwave can be dead for many reasons.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your tech sheet, you can download it here.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 21, 2008 | Whirlpool MH1140XM Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
245 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
