Question about Vehicle Parts & Accessories
Mazda rx8 alarm
The batterie died on I needed to replace it. Now I think the alarm kill switch was activated. The problem is that I know it is after market but don't know what brand it is. I also don't have the keyless remote control. Help
  • jarnold5019 May 10, 2009
    1999 cutlass.Changed intake gasket,and now theft system is on,and will not clear.Turned ignition on for 10 min.and then off.This is supposed to reset it,but it did not reset
  • 22 Answers
Search through the area in the footwell of the drivers side. There will be a very small button. This is a valet/progaming button that is on all aftermarkets. It may be by itself, it may be connected to the brain unit, or it could even be attached to the alarm antenna, which is usually on the windshield. You need to press this button when turning on the car some alarms you need to hold the button down others you just need to press it. This will shut off the alarm until it is reactivated with the key fob.
Posted on Dec 04, 2008
Where do you find fuel pump switch for a mazda RX8
Do you mean the fuel pump crash cutoff switch? It takes a 3G rear collision to activate it, if that is not the case you have another issue.
May 12, 2016 | Mazda Cars & Trucks
Changed the battery and it set off the alarm. it seams like it activated a kill switch of some kind. is there a way to reset it?
You probably had your alarm set when you took out the old one. Just unlock your doors with your key fob, then disconnect the battery again for a few minutes and let it reset with the alarm off.
Mar 14, 2016 | 2000 Ford Econoline
Changed battery in rain have lights engine turns over but no fire
The rx8 has the rotary ankles engine in it, these have porcelain tipped rotors instead of pistols and are prone to wear resulting in them not starting. The car should start with a bump or toe start. This will require an engine strip down and rebuild and should only be carried out by a qualified mechanic. (Mazda recommend rotors be replaced every 25000 miles)
Let me know if this helps
Dec 31, 2012 | 2004 Mazda RX-8
Mazda 6i alarm going off and battery dying
The alarm is going off most likely due to a defective battery in the car, this is caused by low system voltage, so you have it backwards. Have the battery load tested by Autozone it is free.
Sep 04, 2012 | 2005 Mazda 6
Jumped started my rx8 now the alarm is stuck on
same thing happen to my truck when i needed to jump start it what i did was take of the negative put the key in the ignition dont turn in on all the way just so the power will be on when you connect the negative back on
Jan 28, 2010 | 2004 Mazda RX-8
How do I fix the power steering n my mazda rx8 04?
My RX8 had the same problem. First, change your battery cable ends. On the Positive cable there is a white wire that powers the power steering. It probably has a bad connection at the battery post. I cut the end off my rx8 and just put a regular battery cable end on it and my problem was solved.
Jan 06, 2010 | 2004 Mazda RX-8
I recently had my car jump started and now when I put the key in the ignition, the hazard lights flash and the horn sounds continuously.
need to reset ur car alarm, once battery dies down and u boost her up, the car alarm becomes activated. Just shut off the alarm like u usually do before starting ur car.
Nov 27, 2008 | 1987 Mazda 323 4-Door
Vehicle Parts & Accessories Logo
2,149 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
