Question about Samsung SCX 4521F All-In-One Laser Printer
SAMSUNG Multifuction Printer-''Open Heat Error'' (SumsangSCX-4215F)
Please provide steps also on how i can go about removing / changing the Fuser Unit.
two days being trying to crack down ta problem
appreciate your help
Rgds
Basil
  • 77 Answers
Check the thermostat in the fixing unit. it may open due to over heat. replace it. clean thermister.if spoiled replace it also.
Posted on Feb 05, 2009
  • ravi sajja
    ravi sajja Feb 06, 2009
    remove rear cover.at the top there is the fixing unit. disconnect two connectors.( heater and thermister) unscrew the fixing unit.
    Novelist:
  • 159 Answers
Samsung says you should send it in for service, and lists service locations. They also say the fuser typically dies after 50,000 pages -- 100 reams, which doesn't seem like -that- much.
You may be able to call a service center and see if they can help.
I did a search and found someone purporting to sell a service manual for $10; I don't know whether this person is credible and legitimate and legal.
http://www.tradebit.com/filedetail.php/3278061-samsung-scx-4521f-printer-complete-service-repair
You may try to see how much the service manual costs through Samsung itself.
Posted on Dec 05, 2008
Samsung ML3051N open heat error cycle power
check the fuser assy thermostate , if pressor roller melt then change the fuser assy
Feb 19, 2011 | Samsung ML-3051N Laser Printer
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
Open heat error
this means the fuser isnt heating up or sometimes that the printer doesnt sense it heating up, to work out which one applys to you leave it turned on for a few minutes and feel the rear vent, if it is warm then the fuser is good and the sensor is faulty, if its not then the fuser lamp needs replacing, either isnt usually a "user servicable part". get the best idea of the exact issue and approach a repair shop or samsung service provider. if its under warranty contact samsung. if its not get a quote if its more than you think its worth sell the printer with this fault described.
Nov 03, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Failure to print
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
May 21, 2008 | Samsung SCX-4100 All-In-One Laser Printer
ENGINE FUSER, LOW HEAT ERROR
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
How do I fix an Engine Fuser Low heat error on printer:
UNPLUG AND REMOVE 5 SCREWS ON THE FUSER HOUSEING . CK WITH METER TO THERMOFUSE
Nov 05, 2007 | Samsung CLP-550N Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
600 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
