Question about Samsung HP-R5072 50 in. Plasma HDTV
42 in LG red dot like static on my screen still able to watch
Alot of red static dot just started don't know why check setting even put everything back to factory setting three months old it's been on for about three hours when it accured thanks if you can help
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. I don't know if you've already solved this issue, but If it's only 3 months old, contact LG Technical for Service/Repair as it will still be under warranty. It sounds like a hardware fault and would be better for you to get it done for free rather than have someone mess around with it.
Hope you have sorted it
Tim
Posted on Dec 08, 2008
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
I have poor color and when the screen is dark many red green yellow dots dancing all over on my LG 42 PX5D
This is a common fault on all LG sets with few people offering any solutions. I can offer a solution that could remove 95% if not 100% of the dots.
Remove the back of the set, there are about 40 screws. On the left hand side on a circuit board you will see 3 or 4 blue plastic boxes with yellow screw adjusters in them. The only 2 you are interested in are VR3 "setup" and VR2 "setdn". Mark the location with a marker pen so that you know where the factory settings were. Then turn VR3 fully clockwise. If this does not get rid completely do the same with VR2. This worked for me today, I was about to throw the TV away but I now have a 95% improved screen, sharper and more vibrant picture and saved hundreds. Hope it works.
Dec 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have dots running across the screen
If the dots are red and green, that's normal. Just enjoy your hd picture. actually, I think the dots make it look clearer. The only time I can really see them is when the screen is black.
Feb 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
Band of dot's(millions) across screen only whilst watching in hd mode and whilst using any menu option such as volume etc. dot's not there whilst watching any sd programes
I think I have a good idea of what you're experiencing.
Our minds are so set in the low-def mode that when those extra lines are filled in for high-def it looks like a bunch of dots. Notice everything is so much more clear? I thought the same thing when I watched my first blu-ray disc.
Watch something in high-def and then go back to standard immediately after. You'll notice that you can't get near as much detail off of the low-def.
Those dots are your mind trying to put high-def into low def.
Hope this helps; please rate my solution accordingly
Respectfully,
Don
Feb 05, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Red dots all over screen poor picture more when
This is a "mal-discharge" fault & will need either an adjustment on the Y-Sustain board or a software update to the control board. Contact your LG dealer to arrange someone to sort this out for you.
Oct 26, 2009 | LG 42PC3D 42 in. Plasma Television
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Red dots on screen
just video only what cable uusing how syour dvd player older ?
Oct 06, 2008 | LG 42PC1DA 42 in. Plasma HDTV
LG 42in plasma - Green dots on HDMI channel
The diffusion is slightly out of adjusment. This timing adjustment is difficult and on a single scan LG plasma the proper operation requires voltage settings first, then a scope to finalize the adjustment. I have good luck with this alignment by eye but have had alot of practice. This will require taking the back off and a person with the technical background to set this alignment properly. Sorry no easy fix.
Feb 18, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42" Plasma Red Spots/Mist on moving Black images
I was told this was a ramp voltage setting and any tv engineer can fix it quickly.
Feb 08, 2008 | LG 42PX5D 42 in. Plasma HDTV
AT&T LG PHONE
Check whether your mobile's bluetooth is on, if on thats why u r gettings blue dot on screen
Nov 09, 2007 | LG KG800 Cellular Phone
Samsung HP-R5072 50 in. Plasma HDTV Logo
110 people viewed this question
Henry  Thomas
Henry Thomas
