Question about Maytag Dependable Clean Top MAV5920EWW Top Load Washer
I have a burning smell in the motor - Maytag Dependable Clean Top MAV5920EWW Top Load Washer
  • fychohan Nov 26, 2008
    all seems to be freely movng the belt is fine motor is brand new and the smell and the smoke is from the top of the motor, the machine takes in the water .
    Problem Solver:
  • 4 Answers
The burning smell in the motor could be caused by the motor bears are worn out or the belt is rubbing because a idler pulley is seased . the clutch unit could be seased . your motor has to much load on it something is making it work very hard . . hope this helps you !
Posted on Nov 26, 2008
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
There is bad smell from the motor
Dear Sir:
There can be 3 options: 1) Deck belt smell bad 2) Drive belt smell bad 3) Drive main motor winding burn. Test it and proceed according.
or Course you can do it by yourself or 2) call to service tech.
God bless you
May 22, 2012 | Exercise & Fitness
2001 aurora when fan is on high for a period of time it smells like the header is burning.
Not sure what a burning header smells like, but I would expect two possible smells. First, if the blower motor itself is going, you might smell the windings getting hot - like a transformer burning. If this were the case I would expect that the motor wouldn't spin on the low speeds.
The other smell you sometimes get is when the heater core leaks. Then you will get a coolant smell inside the car and sometimes (usually) a wet carpet as well.
Feb 22, 2011 | 2002 Oldsmobile Aurora
Will drain most of water but will not spin and smell something burning
The motor is probably stuck and burned. Open the door and turn the drum manually. You should be able to turn it easily by hand if the motor is not stuck.
Remove the back panel and use your sense of smell to verify where the burning smell is coming from. The possible source of the smell is the motor or the motor control board located on the left side of the machine viewed from the rear.
Let us know the source of the smell for the replacement guide and for further troubleshooting if necessary.
Feb 22, 2010 | Washing Machines
Washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Jul 31, 2009 | Frigidaire Washing Machines
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Nov 26, 2008 | Maytag Dependable Clean Top MAV5920EWW Top...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Sep 04, 2007 | GE WBSR3140DW Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
