Question about AOpen AX4BS (91.32Q10.002) Motherboard
Don't know where to plug in cabels
Ok I got this mobo and the cords to the whole front panel were unplugged, can anyone tell me were all the cords go(this includes the power switch, usbs, and audio)? please let me know. thank you.
  • Anonymous Feb 15, 2009
    wish the link worked but sends me to a site that is just a search engine for shopping. :( any other site?
    President:
  • 1,901 Answers
Here is a link for the User Guide for the AX4BS mobo.
AX4BS User Guide
Check out page 15. That should give you the info you need.
Posted on Nov 26, 2008
Motherboard booting problems...How do I solve?
Hi
Try to boot with 1 stick of ram then swap it with the other and try again. Next unplug the case front connections from the mobo header (pins). Draw a sketch where they all go so you don't forget. I'm talking about the power switch, reset SW, HDD LED etc. Also remove anything connected to the back panel printers etc. Also remove the mouse and keyboard. Carefully, momentarily short the pins that were connected to the power switch and note results.
If it still doesn't boot, remove all parts from the mobo except 1 Stick of RAM, graphics card, PSU, and of course CPU. Leave the mouse and keyboard unplugged. Try to boot by shorting the mobo pins again. If it doesn't boot it is most likely either the PSU or the mobo. It could also be the CPU or RAM but it is less likely.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | EliteGroup RS482-M754 Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Asus mobo flashes on startup, no video
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Apr 30, 2010 | ASUS M4A77TD Motherboard
D102GGC2 mobo problem
I have built quite a few PCs and I have often found the same problem when trying to boot for the first time. An old trick that might help is to repeatedly energize then drain the PC electricity.
Do this by plugging in the PC momentarily then unplugging it then immediately pressing the power button on the PC while there is no power hooked up. Do this several times over and over again in quick succession. Finally turning on the PC with the power connected. If the power supply on the PC has a switch on it you may use that instead of actually plugging and unplugging.
Also you might try pressing and holding down the "ins" or "insert" key while powering on the PC.
Hope this helps.
Apr 25, 2009 | Intel D102GGC2 Motherboard
Battery replacement
hi there;
hey try to unplug the power cord from the powersupply now open the case and unplug the powersupply to the the motherboard and then press the reset button on the front for 15 seconds and than connect the motherboard powercable and plug in the powercord back in to the powersupply and try to restart the computer. please tell me if this works and ANY thing that happnes ok best regards mike
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Intel D845EPI/D845GVSR won't power up.
oon mobo thers pins that go to front finsd ones says pw stick it in eash way try new switch also ove rthose 2 pins ok to get itto light up could be bad mobo
Oct 07, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Will not power down, bios code 7F,
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Aug 27, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
AOpen AX4BS (91.32Q10.002) Motherboard Logo
109 people viewed this question
Top AOpen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Matthew Spark
Matthew Spark
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
