Question about Lexmark Office Equipment & Supplies
Paper pulling to one side model No x2630 - Lexmark Office Equipment & Supplies
    Problem Solver:
  • 9 Answers
If you haven't already, open the printer cover and check that the rollers are clear of and debris (ie pieces of torn paper) Also remove the paper tray and check for the same type of issue.
Posted on Nov 26, 2008
I have a jam in my printer how do I un jam it
Pull out the paper trays, open any door on all 4 sides and gently pull the paper making sure you don't tear the paper. At the final roller there is often clips that release tension.
Google
make model manual
or
make model paper jam
Mar 13, 2018 | In Office Equipment & Supplies
The A4 tray is denying to close
On some printers and copiers you can completely remove the paper trays. I can't say if that is the case here since you didn't give your model number. However you can try pulling the paper tray as far out as it normally goes. Then try tilting it up or down and see if it can pop off the slide rails. Chances are there is some paper or other debris stopping the paper tray from closing all the way.
Also, look at where the paper pulls from in the tray. It will be the side of the tray with a rubber roller. There could be paper stopping that area too.
Aug 02, 2016 | Office Equipment & Supplies
Every time I try to print something, the paper doesn't pull from the tray straight. It pulls to the left side and crumples the sheet of paper so that it can't feed through the printer.
You do not state the type of printer so it is difficult to give exact instructions, but I know what your problem is. Something is stuck in the paper path on the right hand side, hence the reason is skews to the left because the left side is able to advance and the right is hitting the obstacle. If your printer has a paper drawer, turn off the power, remove all cords and the cartridge. Pull out the paper drawer and then carefully stand the printer on it's back so that you can see where the paper goes as it comes out of the tray. You will likely find your problem right there. If you can repost with an actual model I can give you a much better idea of how to find a paper jam but these instructions should help you.
Mar 26, 2011 | Office Equipment & Supplies
Have Kyocero 2050. Error - Misfeed paper - Open Left Cover and remove misfed sheet. Jam 00. I opened left-side cover and found no sheets stuck anywhere in sight. I can't find Jam 00 definition in...
I was having the same problem with the same model and same error. Then I discovered there's an extra panel you can pull out of the side - it's not the one the display is indicating, it's the one all the way on the side. When you pull on the grey level and it comes down, keep pul;ling on the grey level because ANOTHER panel comes down under that and I found some paper jammed in there. Once I removed it it worked fine.
Dec 13, 2010 | Kyocera Mita KM-2050 Printer
I lost my lexmark x2600 installation disk
Hello. There are drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/aiWCx4. Type the exact model number of your printer (eg. Lexmark X2600, Lexmark X2630) then hit select. On the next page, click on the dropdown for Microsoft, Macintosh, Linux/Unix, whatever the operating system of your computer is, and choose your operating system. Then, choose the correct driver compatible for your computer. Hope this helps.
Mar 27, 2010 | Lexmark X2600 InkJet Printer
Printer starts to pull the paper to left side & jams
You may need to clean the printer. See help here, , and diagnostics here. For other concerns, please consult the product support home page for your model here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper gets pulled to one side when printing commences causing it to jam up inside printer canon 1865 model help please as i am dissabled and need printer for my home biz thanks Brian
there may be some paper debris on the side that is not being pulled, check and see. Also cleaned the paper feed rollers with cotton and alcohol.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Office Equipment & Supplies
Brought a new lexmark x2630 plug it all in start to printer then stops it scans but dosent print
recently purchased a lexmark x2630 and i cannot scan any photos to my hard drive
Apr 23, 2008 | Office Equipment & Supplies
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
