Question about Whirlpool LER8648P Electric Dryer
Dryer will heat on timer side not automatice side of dial
Little assist please. My dryer will not produce heat on the automatic or (energy prefrerred side) but will on the timed side of the dial. What should I check....thank you..
  • rosemont Nov 10, 2007
    My problem started the same way. the timer advances normally in auto dry mode, but no motor and heat. In timed mode. the timer also advance normally but when i select the time, i must hold the knob down for a couple of seconds for it to catch and stay "on". Sometimes, it comes off after a few minutes.
    Wierd!
    any ideas???
    Chris
  • 67 Answers
How long will it run on the auto cycle? is it advancing right through in about 10 minutes?
Posted on Mar 22, 2007
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Dryre won't shut off
please remove vent line from dryer,turn on see if timer starts to advance if so...possible vent line clogged...or dryer has plugged with lint..call if need assistance michael doctor airr appl.repair 843-384-8474
Mar 26, 2010 | Dryers
Our 12 year old kitchenaide prestige dryer's timer gets stuck and it does not shut off automatically
Hi, If the dryer heats in the automatic cycle and the timer still does not advance, try using the time cycle. If the timer still won't advance, you will need to replace the timer.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Feb 12, 2010 | Dryers
Timers are not advancing through cycle. Dryer just continues to run. Thank you for your assistance. Chuck
Hi Chuck,
If the dryer is heating up and the timer will not advance in either time or automatic cycles, you will need to change the timer. If the timer advances in time cycle but not the auto cycle, you need to make sure it is heating properly. The timer only advances in the auto cycle after it reaches a certain temperature.
I hope this helps you at all. Please let me know if I can assist you further in this matter.
Thanks
Vic
My gas dryer isn't producing any heat. If there is a service technician on kine now, can someone assist me with what they think it might be?? It starts and goes the while time, just doesn't dry the...
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Kenmore 74602 Gas Dryer
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
Gas Dryer with no heat or timer
Check the following
http://www.youtube.com/watch?v=rQV-z4f7fvA
If you need more assistance don't hesitate , e-mail us back.
Thank you Was this helpful ?
May 13, 2009 | Whirlpool Dryers
Whirlpool LER8648P Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
