Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper loading problem
I am not able to load paper in my Canon MP 145. Please help.
  • Corne Viljoen May 11, 2010
    What happens when you load paper?
    Guru:
  • Canon Expert
  • 183 Answers
Dear shantanu,
I'll try to help. Well, this is common problem in this printer model. Did you mean that paper jam error occurs in the printer. It seems that drive assy broken or paper feed sensor faulty. Please check my post here for details.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Nov 26, 2008
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
I keep geting remove MP paper
This indicates that the machine 'sees' paper loaded in the multipurpose (MP) paper tray. In order for the machine to print faxes and machine generated reports and lists, this tray must be empty as the machine prints from the cassette. Remove paper from the MP tray.
Jan 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
My pixma mp 150 shows me E 2
Error E2.
Action : Reload the paper correctly and press [Black] or [Color].
Loading Paper
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
- Set the Paper Thickness Lever to the correct position for the paper.
Important : Make sure the stack does not exceed the Load Limit Mark.
Hope this helps.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp 145
check if there is any paper stuck inside..E3 is for paper jam...
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error mp 145
e2 is that it has no paper!
There is no E7 but a service error means that the ink pads are full and need to be replaced, does the machine still work or does it not do nothing at all?
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
94 people viewed this question
old marine
old marine
