Question about Toshiba Satellite A85-S107 Notebook
Unable to change desktop///properties browser not lit up to work.
Toshiba A-105
  • Ekse May 11, 2010
    can you clarify the problem, what are you unable to change?
Eror 105 wifi
Error 105 is one of the most commonly faced errors by a lot of users everyday who are using Google chrome
Error 105 is a DNS resolution error. - Which means when you enter the URL of the website and hit enter in Google chrome, it tries to resolve the IP address of the website using a protocol called DNS (Domain Name System). If chrome is unable to reach the DNS server, the name resolution fails and you get the error 105.
Solution:
Once you have verified from your internet service provider that there is no problem on their end, follow the step by step instructions below.
We are simply going to add a manual DNS address in Windows so that chrome is able to resolve DNS queries.
1) Press [Windows Key + R] to open the "RUN Dialog"
Alternatively, you can also click on the start menu, type run in the search bar, and you will have the RUN Program.
Once you have the RUN box, type in ncpa.cpl and click OK - This would work for all Windows operating systems including Windows Xp, Vista and 7.
2) Next, Choose the correct network adapter (from the icons)
If you are connecting to the internet using an Ethernet cable, then most likely you are using a desktop computer. Right-Click "Local Area Connection" and click "Properties"
If you are connecting to the internet using a Wi-Fi Connection, then Right-Click on "Wireless Network Connection" and click properties
3) After you open the properties window, select "Internet Protocol Version 4 (TCP/IPv4)" and click "Properties"
4) Usually you would be having both the options set to "Automatic"
In the section below, select the "Use the following DNS Server Addresses" and enter the following values Preferred DNS Server - 8.8.4.4
Alternate DNS Server - 8.8.8.8
and click "OK", then click "CLOSE"
You must now test your new configuration by browsing a website - you can also try and browse the website you were trying to get to when you got the error 105.
Jul 06, 2012 | Microsoft Windows XP Media Center Edition...
My toshiba satellite pro is having a slight problem with the screen. the screen sometimes changes and its very rough and unnormal
If I'm understanding your issue, it sounds like your resolution is not set to your preferred resolution. If you're using Windows Vista/7, you can right-click on your desktop and click on Screen Resolution to change it to however you would like to see it. If you are using Windows XP, right-click on the desktop and click on Properties. In the Properties window, click on the Settings tab to change the resolution.
I hope this helps and thanks for using Fixya!
Sep 20, 2011 | Toshiba Satellite Pro L300 Notebook
32 LCD tv pic went out suddenly, sound works, fuse is good, signal is good to tv
You have bad capacitors in this unit. Replace capacitor (location) 2074 which is a 25 volt 2200Mf at 105 degrees. Change capacitor (location) 2081 which is a 35 volt 1200 Mf at 105 degrees. Change capacitor (location) 2066 which is a 16 volt 10Mf at 105 degrees. And to complete final repairs change out surface mount capacitors (locations) 2H08 and 2H09. The part numbers for these two identical surface mount caps is..223886975478. And one should consider changing the color crystal, also a surface mount. The number for this crystal is 823827736071. If unable to do this yourself, find a TV tech and show them this repair instruction. Good luck and show a few hands of support.
Dec 25, 2010 | Philips 32MF231D Television
I want to get Toshiba homepage back. How do I get it now?
left click on your internet browser and open internet properties..........here on the first ypu see homepage now enter web address of toshiba and aplly the changes........now you have yor toshiba homepage back
Feb 01, 2010 | Computers & Internet
Browser windows angrily want a percentage of my big, new monitor
you need to go to the properties of your display settings of the pc. your window size is dependent on your graphics card not the monitor. right click you desktop. goto properties. got to settings. change your resoluton. if you have a better than stock graphics card go to the software that came with the card and change the settings ther.
Dec 25, 2009 | Hyundai X224WA LCD 22 inch LCD Monitor
Light is on monitor but screen not lit
Dear maynardkb,
Try to right click on desktop, choose properties.
When Display Properties appear, click on the setting tab, you have to choose the related display to make the viewsonic work and allow it to run.
GoodLuck!
Best regards,
bionic23
Oct 28, 2009 | Computers & Internet
I have a RCA NiteGlo RC4GLWD remote and a Toshiba tv. Could I get the codes for this please. This is a wonderful site. Keep up the good work.
Press & hold CODE SEARCH until light comes on, then release.
Press TV button, light will blink and then stay lit.
Punch in 3-digit code, light turns off.
Press power button and see if TV turns off or on depending previous state.
The codes listed in the manual for Toshiba TVs are:
049, 071, 072, 089, 105, 109, 117, 118, 160, 162
Sep 17, 2009 | RCA Televison & Video
Everything on my screen seems inflated, though I
Right click on a free space on your desktop and goto properties, the click on the tab that says settings and change the screen resolution to your liking. This should solve your problem.
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Want link for Toshiba Satellite A105 PC Notebook drivers download
Here is a link to the Toshiba download driver area. You will need to lookup your specific model # & then a list of all available drivers will be displayed. Hope this helps & please take a moment to rate this solution. Thanks. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Mar 16, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A85-S107 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
