Question about GE Profile PDW8400J Built-in Dishwasher
GE Profile dishwasher LEDs do not light up.
The LEDs on my dishwasher do not light up when the door is closed. The Start/reset LED flashes when the door is open. However, once it is closed, nothing is displayed.
  • 4 more comments
  • Anonymous Aug 09, 2008
    The panel controls ignition (toushpanel) is turned on or piece and not send the signal to work
    i need front panel because it scrap cable that connects the controls with the board
  • jam4814 Oct 22, 2008
    The control panel light do not light up when the door is closed. I've disconnected the power in hopes of resetting the controls. "no joy" Is there a fuse that may need replacing? Is there something other than having a tech replace the mother board?
  • Anonymous Mar 13, 2014
    Simens SL65M352EU/10 can't close the door and it starts when open
  • Anonymous Mar 31, 2014
    when start buttom is pressed led flash once but does not start
    will not start - leds flash once
  • 3 Answers
You need a new led display
Posted on Jan 27, 2013
  • 87 Answers
You have a bad control pc board.
Posted on Jun 08, 2007
How do I reset the settings on my GE dishwasher?
Best way I have found is to disconnect power (turn off breaker for 30 sec), open the door, turn on and within 60 seconds press ON/OFF and SELECT buttons at the same time (if done correctly, all LEDs flash together), then close door. This enters the service mode (which reset mine with no issues).
Jan 22, 2017 | GE Dishwashers
What does error code E7 indicate on a bush dishwasher
E7 The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
For an E7 fault the PCB has to be reset:
1. With the door open, turn the appliance ‘On’
2. Within 3 secs, push the program selection button ‘P’ 4 times
The test program has been selected if ‘Soak’ and ‘Strong’ LEDs are flashing. (This combination represents the test program for appliances that have a flow meter.
1. If the above LEDs do not flash after carrying out the above procedure, then switch appliance ‘Off’ and repeat process again
Once the above test has been activated and the LEDs are illuminated then:
2. Push the program selection button ‘P’ once to select the version “without flow meter”
bullet Check that the ‘Soak’ LED is ‘Off’ and the ‘Strong’ LED is ‘Flashing’
To complete the procedure:
1. Ensure appliance is switched ‘Off’
2. Wait for approx. 10 to 15 secs
3. Switch the appliance back ‘On’
4. Select the SOAK program to test
Nov 02, 2015 | Dishwashers
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 10, 2015 | GE Dishwashers
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
Lock light is flashing, dishwater will not start.
The machine thinks the door is not closed properly.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | GE Profile PDW8000G Built-in Dishwasher
Drum light flashing on brother printer hl-2170w. what needs to be fixed?
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Nov 05, 2010 | Brother HL-2170W Laser Printer
I relaced the drum yesterday on my HL-2170W but the drum light keeps flashing - how do I get it to remain off?
Open the front door
Oct 31, 2010 | Brother HL-2170W Laser Printer
The drum light has been flashing. I replaced the drum and still can not get anything but a blank page. How do you reset the printer so it recognizes a new drum?
Open the front door
Oct 19, 2010 | Brother HL-2170W Laser Printer
GE Profile PDW8400J Built-in Dishwasher Logo
766 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
