Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Main powerhead useless
Whenever i have the main power head turned on it just shoots everything on the floor back at my feet. If i turn it off it does a better job picking up the dirt than when it is on. Could this be a suction problem? Im not sure what the issue is so i have no idea how to fix it.
Please help!! my cheap $90 vacume did a better job on our carpets.
    Problem Solver:
  • 8 Answers
Make sure that the vacuum hole in the head unit, or the wand, or the hose is not blocked. You may also want to check the bag to make sure that the inlet hole is not blocked. The only reason for spitting things back out is that the suction is not working properly...
Posted on Nov 28, 2008
Filter queen majestic power head not working, main vacuum working but no power in head when plugged in. any suggestions as to what may be the cause for this to happen.
Is there power at the head, have you checked with a volt meter, most likely if not then the cord to the head is defective.
Aug 31, 2016 | Filter Queen Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
The dirt isn't making its way to the canister . . . what could be the problem? I have taken apart everything I know to take apart to check it.
Generally this is due to a clog in the hose.
Disconnect both ends of the hose, hold one end up and drop a coin into it. Raise the hose so the coin should drop out. If it doesn't there's a clog. It can usually be pushed back out with a broom stick. Push toward the powerhead end.
A blockage in the powerhead above and behind the brush will also cause this. One here can usually be pushed out using a wooden spoon handle.
Is there even suction at the power head? Drop a bit of paper on the floor and try to vacuum it up to find out.
Jan 29, 2011 | Dyson DC14 All floors Bagless Upright...
How do I change belt in power head? Is there a
There could be 2 different ways to access the belt on the kenmore line of powerheads...
1) turn the powerhead over so that the bottom is facing up. IF there are screws on the bottom, remove them. There should be 2 either at the back where the rear wheels are, or one under the elbow, and one midway at the front under the lifter wheels. remove the screws, and there should be two tabs on the sides to remove the top cover. OR 2 tabs at the back of the unit near the screws to remove the top cover.
2) and this is the more common powerhead...
remove the light cover for the powerhead by pressing at the two sides and pulling the cover up. sometimes a screwdriver to pry open a little will help.
Remove the light bulb.
Remove the two screws.
Turn the head over and pry at both sides to pull the top cover off.
Good luck with either one.
Nov 18, 2010 | Kenmore Vacuums
My powerhead shuts off on its own and then i must push the switch again.
Just had this with mine and I think it is the power wires embedded in the hose from the cleaner to the powerhead. Turn the cleaner on then work your way along the hose kinking it or moving it until the power head stops. Switch the power head on again and kink the hose in the same place, if it turns off every time like mine, that is where the break is. I haven't worked out if the cable cores can be replaced or repaired yet. Hope this helps. Chris.
Aug 18, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Belt for heritage 2
remove power head turn knob on front counter clockwise look in hole on back of powerhead make sure belt is on the hook install powerhead back on motor turn knob clockwise
Jun 22, 2009 | Kirby Heritage II Vacuum
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Dec 24, 2007 | Vacuums
Kirby g4
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Dec 08, 2007 | Vacuums
How to put the belt on ?
Dec 06, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
124 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
