Question about Onkyo Audio Players & Recorders
Onkyo receiver won't stay on - Onkyo Audio Players & Recorders
  • 905 Answers
This is a protection circuit stopping any other dammage to the unit
it will need some testing to find the culprit
electech
Posted on Nov 26, 2008
My Onkyo TX NR609 is not coming on and immediately shuts off and is progressively getting worse it is hooked to a harmony smart hub
Hi Liz, I am sorry about your issue. Please remove the HDMI cable from the receiver that is connected to the TV as a test. Check and see if the receiver stays on. If it does not the receiver would need to be serviced. Thank you, Onkyo USA
Oct 29, 2016 | Onkyo Audio Players & Recorders
DISPLAY STAYS WITH THE ONKYO DISPLAY AND THATS IT
The video card to your Onkyo is OK, as it displays the Onkyo Logo. Contact the authorized service center for Onkyo. A firmware update is necessary. With a Corrupted firmware, this kind of display effects can occur. Gopakumar Gopalan Google
Feb 28, 2014 | Onkyo TX-NR905 Receiver
Hello! need help please my onkyo txnr616 when
possibly a problem with the receiver. first you could try a power cycle, unplug power cord of receiver for a minute then plug it back in and try again. if you still have the problem disconnect all speakers and see if the receiver will stay on.
Nov 03, 2013 | Onkyo TXNR616 Open Box 7.2-Channel 3D Home...
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
My onkyo tx-sr605 7.1 a/v tuner will not switch from game/tv to cable/sat or any other mode. I can't even get into the setup moder It won't power on even if I press the power button manually.
You have this all backwards. So essentially it won't power on. THAT must happen before setup or anything else.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Onkyo TX-SR605 Receiver
My onkyo tx8211 stay on a stand by mode. I can
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
May 16, 2010 | Onkyo TX-8511 Receiver
Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Sep 10, 2008 | Onkyo TX-DS989 Receiver
493 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
