Question about Ovens
Kenmore oven does not seem to be turning off.
We were cooking a frozen pizza tonight, my son checked on it thought it needed to be on for a couple of more minutes (set the time for two min, so he says), we went in a couple of min later to check on the pizza and it was totally scorched, the oven temp seemed very high and the reading on the screen read some type of error. I pushed off button, the broiler element seemed to be on, pushed off again, nothing happened. I then pushed the broiler button, turned down temp and then turned the off button. Elements are not lit up, but it appears that the oven is still on, at least it is not cooling down. Help.
  • 338 Answers
If the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Posted on Nov 26, 2008
Electric Oven will not heat or come on
Sounds like you have burned out the element?
Aug 12, 2015 | Ovens
Lincoln Impinger 2 Double Conveyor oven temperature unstable
It looks like a thermostat problem, but if the thermostat had already been replaced, remain to check the valve and the pressure switches.
When the valve is defective, gas will turn off and not restart, Check and eventually replace the pressure switch , but it can also be a control problem.
Let see if I can find support and repair in your area.
Oct 08, 2008 | Lincoln Conveyor Oven - 1133-000-A
When cooking Pizza at 220c the top burns-even though the element is on the top and the pizza in the bottom third of the oven, and the base is uncooked - this also takes 30 minutes to cook?
you are using the broiler to cook it,the upper element is the broiler,the lower one is for the oven,turn on the oven so that the bottom element is on,if it doesnt work,then that is the problem
Jul 19, 2015 | Ovens
MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
May 04, 2011 | Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
Kenmore gas oven
after the gas stove have been on a while a loud whoosh that is a constant thing comes on. I thought it was getting ready to explode. I took seconds after we turned the gas off for the noise to stop. Any ideas what this coud be
Jan 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Feb 07, 2008 | Blodgett DFG-100 Gas Single Oven
Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Dec 30, 2007 | Ovens
Ovens Logo
93 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
