Question about Compaq Presario SR1000T (568657) PC Desktop
When comp pluged in just a green flashing light
Computer fans not running or booting up just a green light on power pack and front of computer flashing.. as makes a click sound every time green light flashes
I had the same problem but was fortunate to solve it in a much simpler and cheaper way - try this first!!
There is a small red slider switch on the back panel of the computer, which is also the back panel of the power supply, near the 110 V power inlet. The small red slider switch is for 110V or 220V. If it is not solidly seated in the 110V position, this problem (no bootup, flashing green lights etc) will occur. I suspect my switch jiggled out of place just by jostling the computer over time. Anyway, Just slide the switch back completely into the correct position and voila! Problem solved. If that does not work then proceed to replacing power supply etc.
Posted on Dec 16, 2008
  • 2,692 Answers
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Posted on Nov 26, 2008
Flashing green light on power supplyonly fans come on at start up
just open ur pc case replace the ram and all connections for 5 to 10 min clean dust inside pc and also clean ram and put back in to pc and restart i hope ur comp will be right back to normal!
Aug 02, 2010 | HP (152769-001) (152769001) 250-Watt Power...
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Dell computer will not turn on.
Somewhere on in the tower there should be a sheet representing what formations of lights mean which...
Maybe you got bad RAM?
Maybe your Harddrive is dead?
Maybe your motherboard is fried. I should tell you.
Good luck.
Jul 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the might have to flash the bios and reinstall do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
No Opening - The computer center control cover (A) continals to flash for 10 Seconds only
Make sure your power cord is pluged in and the indicator light in front is yellow (saying that it is "charging") - these cords are known to go bad quite often.
Your computer is saying there is not enough battery, or power to keep it from booting all the way up.
Mar 28, 2008 | Dell Latitude D505 Notebook
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
Hp 1270n power problems
Sounds as if your power pack might have a problem.blown fuse ect.I whould remove the cmos battery and or change jumper pin setting to start fresh in the bios settings.after removng the cmos battery,Make sure to put it back in before you re boot your computer. Good Luck garydalel
Dec 29, 2007 | Gateway (4000811) Motherboard
Compaq Presario SR1000T (568657) PC Desktop Logo
281 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
