Pioneer SD-P6093-k Convergence issue
I have a 60'' pioneer projection and the blue color is off like a good 5'' from the center of the TV.
is there a way to fix this or do i need to buy something?
ive heard something about IC's... what are they exactly, i am electronically savvy just never worked with Tv's before. anyone wanna fill me in on what an IC is and does. and what the part number i need would be so i can replace both of mine. and whatever else may need/ want to get replaced at the same time
thanks
    Top Expert:
  • Televison & ... Master
  • 75,767 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence procedure to many brands of projection TVs are given in detail.
Posted on May 19, 2017
SOURCE: Blue convergence on Pioneer SD-532HD5
The converence IC's are the problem. Unfortunaely, I do not a service manual for that unit. You will find the IC's mounted on a large heat sink. The nuers usually start with STK-xxxx. Find these IC's and copy the number off them. Usually the can be replaced by generics. You can order them directly from Mat Electronics 1-800-628-1118. Be extremely careful when you desolder these ICS the foils are easy to lift. Use desoldering braid(chemtronics) 10-25L. Also ask for BOB and tell him that Tom from TOM's Tv suggested him. This will insure you the lowest price. Also some times the current limiting resistors open up. Always replace both convergence ICS. In your case only one is bad. Replace both anyway. (they only cost about $12.00 @ Any further questions, contact me. These are great TV's and well worth repairing!!! Scrivitron
Posted on Jun 22, 2007
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
Posted on Sep 08, 2007
SOURCE: HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
b40-756cp
Posted on Jan 09, 2008
SOURCE: rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: Sony HDTV Convergence Issue
I have the same issue, on my 60pp9202. It works some times, and then its ok. If I leave it on, it will be ok, until it gets turned off.
Chuck
Posted on May 09, 2008
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
My Pioneer PRO-200 60 in. Rear Projection Television picture looks great however it appears to be dark and blacks all blend together on the screen.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Pioneer PRO-200 60" Rear Projection...
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Chgd convergence chips,red looks "out".
you just want to select one color like red get it centered and then do the blue and center that one. the center should now be white, go onto the next one.
Oct 20, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
