Question about Quantum ATL P7000 (p7-0/679-nds) LTO 2 Tape Drive
Add new SDLT600 drives to a P7000 ATL
I've added 4 more drives to our P7000 + 1 FC470, to support them. I've made sure the termination is in place (termination LED is on on each drive).
However, once I power up the ATL, the drives don't stay powered on and the neither the ATL or the FC470 can't "See" any of them. I've logged on the the FC470 and tried to discover devices but nothing is there.
Does anything else need to be done on the ATL side?
Thanks
2 Suggested Answers
  • 2567 Answers
SOURCE: I have a Quantum ATL
SYMMPI is usually found to be an on-board SCSI controller. The ADPU160M is one flavor of driver for Adaptec SCSI controllers. So, a failure on one controller and success on another is not unusual. These type of errors are not specific to SYMMPI1, but more an issue between controllers and the attached tape hardware. Microsoft has a KB article that references the most common errors seen: http://support.microsoft.com/?kbid=154690 As stated in the KB, these errors CAN be driver related. But, if you've replaced or upgraded drivers, and are still seeing these errors, it's unlikely to be a driver problem.
Posted on Dec 17, 2010
Maximum hard drive capacity for vgc-rc110g
caviar black 7200 rpm scorpio 1tb good hd.western digital.
Jun 05, 2012 | Sony VAIO RC110G (VGC-RC110G) PC Desktop
Intel 31 3 beep sound solve
3 Beeps usually means a memory issue. If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Jun 02, 2012 | Intel DG31PR Motherboard
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
Transaxle light comes on when driving longer distance at higher speeds. i think i just need to add transmission fluid but cannot find the place to check or put it in at. i found a little spot next to the...
yes that is where you add CVT(continuously variable transmission fluid), I would check with the dealer before adding any regular ATF, make sure you have the right fluid before you ruin your transmission and are left with a hefty repair bill!!
May 13, 2011 | 2009 Jeep Patriot
The tape library ATL 7000 that POST failed and report SK=6 ASC=80 ASCQ=00
DOOR WAS OPENED INVENTORY MAY HAVE
BEEN CORRUPTED
Close door and retry command.
just check the front door and rear door closed, check the sensor of the doors if need.
Sep 12, 2010 | Quantum ATL P7000 (p7-0/679-nds) LTO 2...
I'm trying to replace rear speakers in my 99 ford expedition and i'm trying to find out the size and how to install
Ford usually fitted elliptical speakers in their models in the 1990's so it's possible that yours are 6"x9" or something similar.
You can get replacements from Ford, (which are usually very expensive!) or buy some better ones on the Internet, such as Ebay or Amazon.
I bought a pair of German Blaupunkt 6x9's for my car from some site I found on Ebay and the price was around half of that to buy the *same* speakers from Ford Spare parts Dep't!!!
The sound is fantastic!
PS: You should be able to access the rear speakers below the rear parcel shelf at each side of your Expedition. They are held in place by 4 screws, which usually have a Posidriv (+) type screwdriver head.
When refitting, make sure!!! that you fix the +ve spade terminal to the +ve marked on your new speaker & the -ve terminal to the -ve. Do this on both speakers to make sure that they are both in-phase (so both bass drive units are pushing air forwards together). If you don't keep them in phase, the speakers will produce much less bass - which is clearly noticable!
Hope this helps
Nov 17, 2009 | 1999 Ford Expedition
SDLT 600 dont detect the correct media size, for example, it detect 100gigs and has to detect up to 600gigs
Are you using the right media? These drives can take older smaller capacity tapes!
If you are indeed using the SDLT600 R/W Media in a SDLT600 drive then can you actually get more than 400 GB on the tape?
If yes then it is just a glitch in the software that you can ignore if no then i still think it is a software problem and you might need to try changing backup software to see if the fault changes
Aug 11, 2009 | HP StorageWorks SDLT 600 Super DLT Tape...
Adding extra internal hard drive.
make sure you pc is turned off before you start. To add additional internal hard drive you will need to get SATA hard drive. when you open up your pc there will be a slot to put it in. on the new hard drive there will a display with shows you how to make that hard drive a slave. move the little thing to the right place and plug it in. when you restart it should read it .
Dec 16, 2008 | Computers & Internet
Quantum ATL P7000 (p7-0/679-nds) LTO 2 Tape Drive Logo
Top Quantum Computers & Internet Experts
SirEbrum
Jax Planet
Jax Planet
Alun Cox
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
