Question about Denon AVR-3806 Receiver
Denon 3806 Receiver Set-up HELP!!
Trying to set-up a new Denon 3806 Receiver. Only making it through the inital 3 steps before hitting a few snags. Keep getting an error message that the system isn't recognizing one or the other front speakers and the rear speakers. We've completely shut everything down, unplugged everything, then re-setup all the speakers only to start the set-up again to find that the other front speaker isn't being recognized yet -- the other front speaker is working now!! We are pulling our hair out -- any help would be appreciated!! Thanks.
  • Dennis Scroggins May 11, 2010
    you may have to switch the neg/pos wire at spkr or amp and try setup again
SOURCE: Denon Receiver flashed PROTECTION and stopped working after plastic smell
i just had the same thing happen to me what did you do to fix it?
Posted on Jan 04, 2008
SOURCE: No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Posted on Apr 02, 2007
SOURCE: denon Avr-588 setup
I am unable to get video with new oppo dv-981. All HDMI connects but no video or set-up menu for new HD DVD. Can anyone help?
Posted on Feb 12, 2008
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
tech48
  • 624 Answers
SOURCE: Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Denon AVR 3806 Philips 42PFL3603D/F7 Compatibile
Make sure the control feature is disabled on both units so that they are not trying to send control signals to each other.
Secondly make sure your input is configured to hdmi for both audio and video within the receivers on screen menu The receiver usually auto senses the digital audio signal but doesn't automaticly know that it should use hdmi for video.
Dec 19, 2009 | Denon AVR-3806 Receiver
Denon AVR-3806 keeps losing video signal. The audio signal is still good. What could be the problem?
If your using HDMI, pull it from the receiver and run directly to the TV, then run optical or digital coaxial to your receiver. It's referred to in the industry as a "Handshake" issue. It has to do with firmware and hardware of your receiver and continuous ridiculous updates from the recording industry to protect copyright. Hope this helps. If you still have issues, post a comment and I will help you troubleshoot further.
Sep 20, 2009 | Denon AVR-3806 Receiver
My Denon AVR 3806 keeps turning itself off, why?
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Jul 06, 2009 | Denon AVR-3806 Receiver
I have a Denon 589, PS3 and Sharp Aquos. Using HDMI cables, PS3 to TV directly = great signal. PS3 to Denon to TV= no signal.
ON PAGE 98 OF YOUR MANUAL YOU WILL SEE THE RES OF 1080P ARE NOT HANDLED SO YOU SET YOUR PS3 RES TO 1080I, 720P YOU WILL HAVE PIC FROM YOUR PS3 TO YOU DENON TO THE TV
Nov 27, 2008 | Denon AVR-3806 Receiver
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
Jan 08, 2008 | Denon AVR-3806 Receiver
Set up Denon AVR 3806 to HD DVD player
Geesh! Finally found it in that encyclopedia of an instruction manual. If you have the manual, the solution is on page 63. If not, I'll provide an attached image below.
Dec 23, 2007 | Denon AVR-3806 Receiver
Denon AVR-3806 Receiver Logo
159 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
