Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox VCR/DVD player CMWR 20V6
The VCR plays for VHS tape for 7 seconds then stops, shuts off and expels the VHS tape
  • jpower715 Jan 08, 2009
    I have the exact same problem! I bought this a year ago but only dubbed off one of my old home videos to dvd. I started to do another today and this started happening. Anyone got any ideas?
The same thing happened to me and it is the power supply. You can get a new one at
Posted on Sep 10, 2009
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Jan 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
294 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
