Question about Yamaha RX-V2600 Receiver
Video signal drops out
HI. I just receieved a brand new RX-V2600 and spent a few hours studying the manual and getting everything hooked up. My problem deals specifically with the video from my satellite receiver dropping out. I have my satellite receiver outputs run to the V2600; the video via S-Video cable. I also have a DVD player hooked up to the Yamaha via component cable. The signals from both then run to my Sony rear projection (50" Grand Wega) set via HDMI. The problem is, the video from the satellite signal drops out after a few minutes and then continues to cut in and out. The audio is fine. I ran the s-video cable directly back into the TV to make sure it was not a problem with the Dish receiver. It works fine. Heat does not seem to be an issue, as I have the receiver setting out in the open, and also set the cooling fan default to continuous just to make sure. I found out after the puchase that I did not but the receiver from an 'authorized' dealer and that the warranty may not apply. Yikes! Any ideas? Thank you. By the way, the DVD function works perfectly.....
  • fredpamm Sep 08, 2008
    I have the same problem where my HDMI signal out of the receiver drops out..
    President:
  • Yamaha Master
  • 1,114 Answers
Well, I have a solution and a question. First, why do you have S-Video hooked up from the sat receiver? is it a non- HD unit? Does it have component out? if so use it. Next; your receiver, as awesome as it is,it is 3 model years old and the HDMI firmware that was used in 2005-06 was version 1.1 which unfortunately for all of us was a "failed" format when using DSS,Cable, or FIOS. The problem was passing the DHCP copyright protection format from one source thru another to a third. Sounds complicated, I know, but that's what the issue is. The Good news is; the human eye cannot tell the difference between 720p and 1080p on any TV set 50" or smaller, and that is a fact. and the 2600 would only convert from s-video to 1080i which is equal to 540p. So, to make a long story short and understandable, if you use a good quality component cable to your TV set (Monster, Phoenix Gold, Apatchure, etc) your picture quality will not suffer and there is no reason to be upset at your receiver since it was firmware provided by HDMI not Yamaha and was a problem on every receiver made with 1.1 firmware. So here's what you do Hook up your Sat receiver component (if you have it) S-vid if you have to, and any other sources that are going to pass video thru your receiver either s-vid,component, or standard vid. The only exception would be a blu-ray DVD. I would run HDMI direct to your TV, then run digital coaxial for audio to the DVD Digital audio input of your receiver. You have an awesome receiver that has lots of cool features and a bullet-proof electronics! enjoy it! Hope this helps. If you have any more questions, post a comment and I will help some more.
Posted on Jun 07, 2009
HDMI Error/HDCP Error
Hi, Try replacing the HDMI cable. My Guess is that you have a bad cable connection or connector. If there is excessive heat on cable connectors this could be bad. Cooling fan or other heat source
Good luck.
Jan 13, 2014 | Yamaha RX-V2600 Receiver
Yamaha RX-V2600 completely dead ... any ideas
If it is plugged in to a working outlet, and the AC cord is not broken, there is a problem in the power supply of the receiver. This provides all of the DC voltages that make all functions work. If it is completely dead, the display, the lights, the audio, (everything) is not working; and it is not likely there are separate problems in all of these areas at the same time.
Feb 17, 2013 | Yamaha RX-V2600 Receiver
How do I hook my PS3 gaming system into my Yamaha Rxv2600 receiver. I can get sound but do not get video. I had to use component video from the receiver to the TV because that was the fire code for...
Use HDMI - I don't understand what you mean by "fire code". HDMI uses less cable involvement, where as component uses five cable to produce video - no audio. HDMI accommodates the audio signal as well. However, if you want 1080i, this will only work for component - you need 1080p for HDMI.
Jan 20, 2011 | Yamaha RX-V2600 Receiver
Loose hdmi monitor out connection brand new cable
hd EZ lock may help your issue. It's a Universal Locking HDMI Cable Adapter which acts as a strain relief and HDMI Cable lock. It is very effective in eliminating intermittent signal loss caused by a loose connector, as well as eliminating harmful stress on an HDMI Input caused by a heavy HDMI Cable.
It's universal and works with most HDMI Cables and most HDMI Components, and typically installs in minutes. Here's a short video showing installation:
http://www.youtube.com/watch?v=-AyR9higu0M
Sep 22, 2009 | Yamaha RX-V2600 Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
RX-V2600 HAS BLOWN FUSE CB5 10A 250V REPLACED NOW RECIEVER WILL CLICK THE RELAY ON THE OFF ANY SUGGUESTIONS WE CHECKED ALL OUTPUT TRANSISTORS
check the DC converter and associated transistors. an overload may have taken some out, and rendered the unit useless.
Jun 11, 2009 | Yamaha RX-V2600 Receiver
Is the onkyo mic optimizer compatible with yaama receiver
No, they are brand and model specific. If you visit a local retailer that sells Yamaha, tell them your model # and they may even have a mic you can use. If not, let me know, I'm a Yamaha dealer and can get it for you or point you in the right direction to get it. Hope this helps
Apr 27, 2009 | Yamaha RX-V2600 Receiver
Since hooking up my dvd player(blu-ray)with hdmi, my video completly drops off after the receiver has been powered up for about 3 mintutes. This is not a problem when using component input and output- only...
The RX-V2600 is first generation HDMI and the firmware is HDMI 1.1a or b It will not pass video via HDMI. It's not a Yamaha problem, it was an HDMI problem. Every receiver with 1.1 or 1.2 firmware has issues. The newest version is 1.3b and so far so good. I'm a home integrator and still am leary of HDMI for that very reason! expensive cables too! if you are viewing on a TV 50" or smaller, the human eye cannot see the difference between 720p and 1080p. if your TV is bigger, run the HDMI directly to the TV and run Digital Coaxial or Optical audio to your receiver. That is the only solution. Hope this helps
Mar 22, 2009 | Yamaha RX-V2600 Receiver
Yamaha RX-V2600 Receiver Logo
297 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
