Question about Olde Thompson PWZ500
I'm trying to sew leather, but the thread keeps balling up on itself , like unraveling kind of. What am I doing wrong?
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Dec 29, 2016 | Sewing Machines
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
Mar 07, 2015 | Juki DDL-8700
Needle string wont stay connected
You are missing one of the steps in your threading pattern. Sometimes it is going the wrong direction when threading the machine. Check your owners manual or go on line to the manufactures website and it will give you tips on what to do.
Sep 22, 2012 | Euro-Pro 1260DX Mechanical Sewing Machine
Pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
Aug 16, 2012 | PfaFF Sewing Machines
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
Sewing 1/4" leather. Bottom thread
You did it backwards!!! Reset the bottom tension to the default position, with heavy threads its touchy to get back to normal. Turn the upper tension about 1 turn clockwise (tighter) and try. No luck, try a turn then test, then a turn, test.....The size of the thread can cause issues as well. We mostly use #69 nylon threads, but the 1541 can use # 69 to 192 without to many problems. look in the book for how to reset the bobbin case tensions. The 1541 is a wonderful machine, much better quality than the chinese junk being sold nowadays.
Jan 15, 2011 | Juki DNU-1541 Mechanical Sewing Machine
I am sewing leather, less than 5/8 or just about thick and my upper thread keeps breaking or coming out of needle. i am using a leather needle, which i changed, cleaned the race, adjusted tension, using 50...
What brand leather needles are you using? Keep machine out of Sun ok. All leather needs to be in cool or room temperature. try loosening bottom tension just alittle or top tension, I would start with bottom......I also use commercial polyester thread when doing tougher materials..
let me know
Nov 28, 2009 | Brother CS-8072 Computerized Sewing...
Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Aug 24, 2009 | Brother XL-3510 Mechanical Sewing Machine
Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Jul 29, 2009 | Sewing Machines
NewHome L-372
You are sewing heavy thread in a machine designed for sewing clothing but it can be done. Use a size 18 needle or a top stitching needle(it has a larger eye). Thread the machine and adjust the tension to 8 or 9. Set the stitch length at 3 or 4. If you still get loops on the bottom, wind the thread around the bobbin winder thread guide once for more tension and then thread it normally. If you do this, lower the tension to 5, test sew and then tighten the tension until the loops go away.
Aug 05, 2008 | New Home L-372 Mechanical Sewing Machine
Olde Thompson PWZ500 Logo
56 people viewed this question
Top Olde Thompson Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you an Olde Thompson Sewing Machine Expert? Answer questions, earn points and help others
