Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My washer will not fill with water , it just hums lightly when you pull the knob to start FEX831CSO
  • Anonymous Jan 17, 2009
    I am not familiar with fixing this stuff, but I have the same issue, how do you check whether the faucet is on (I am guessing you don';t mean just any faucet in the house) and how do I check screens inside the fill valve?
    Sergeant:
    Champion:
  • 324 Answers
Check your hoses make sure the faucets on,check the screens inside the fill valve.
Posted on Nov 26, 2008
Washer didnt drain all the way and now i keep gettin a code. n the light for the door lock wont come on
If water is in tub and the control tries to drain tub but water doesn't drain, then the unit will not operate. Most LG have a drain pump clean out located behind the access door on lower side of washer. Open the door and you will see a black tube with a cap and a round knob. First, get a bucket, pull the black tube slightly out and remove cap. The water in the tub will start to drain and you may have to fill bucket many times to get all water out. Next, unscrew knob and a little screen will pull out. Inspect this screen and inside of pump chamber. Your looking for any thing that could block the pump. If pump hums and still doesn't drain, the drain pump is more than likely bad. Good Luck
May 25, 2016 | LG Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Frigidaire Model FEX831CSO washer doesn't work.
The pump that expels the water may be clogged or have a broken gear they are plastic. Thing like baby socks find their way into them and the clogged or break. New pump will be about 60 dollars if that is the problem, and someone to take old one out and put new one in. The diagram is usually somewhere on inside wall of washer taped, it includes a trouble shooting chart and part numbers.
Jan 19, 2018 | Washing Machines
Not filling
The water inlet valve is stuck shut and will need to be replaced. Here is the part you need.
Oct 19, 2012 | Kenmore 98702 Stacked Washer/Dryer
Even humming sound made when washer starts continous
Most likely a motor or solenoid has a loose coil or its magnetic field is vibrating a nearby piece of steel. If it hums all of the time except when the washer is filling, it is the timer or main motor. If it hums only when the washer is filling, it is one of the water valves (you can isolate by selecting hot or cold instead of warm for one of the cycles).
The timer motor is on the control panel right behind the cycle select knob. The main motor is under the tub. If the main motor is humming, it may be overloaded, but in that case, the humming should diminish as the motor gets up to speed.
Jan 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
It started out not spinning. The lights would
kenmore portable washer will fill with water when button pulled out it just hums and occasionally tries to start.
Jan 30, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
Humming from Water Solenoid area
It may have some dirt or sediment clogging it making it work harder than usual.
Jan 23, 2009 | Washing Machines
Frigidare washer hums loudly and doesn't fill with water
I figured out what was wrong with it. We narrowed it down to the pump or the timer. We determined that since the machine was spinning when the lid was down and it was spinning no matter where the dial was set, we figured it had to be the timer.
We did have one issue getting the dial off the washer. The trick to it was to remove the pin from the middle of the timer and the dial just came right off.
It was an easy fix really and the timer cost us $95.00 Hope this helps someone else in the future.
Jan 05, 2009 | Washing Machines
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
165 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
