Question about Sony Cyber-shot DSC-W55 Digital Camera
My sony cybershot got wet
It was totally submerged in water for a couple o seconds, it was turned on when it fell. what should i do?
  • Sony Master
  • 586 Answers
    In this situation don't turn your product on ever untill unless you must sure that the wetness been remove into its inner.For this you have to take some percautive measurs,Which are
1- Get out the bettery from battery compartment.
2- In day light put a cotton cloth on you product and keep it in sunlight for couple of hours (cotten colth is for safty purpose,Because dont put the product in direct sunlight)
3-  After the completion of the sun light or also you can use bulb light for eveporation, If you have blower then dar it from blower.
4- Then after wait for minimum one day.Then turon it on and it will start working fine again.
Hope you will understand all the procedure.
THanks,and dont forget ot rate.
Posted on Nov 28, 2008
MY SONY CAMERA GOT WET ITS NOT CAPTURING PICTURES OR NOT RECORDING VIDEOS. EVERY THING IS WORKING BUT THE SCREEN IS NOT DISPLAYING WHAT DO I DO??????
sir,
if your camera or any electronics appliances happened to enter water or moisture, you must remove the power source(battery)at the immediate, hence the water is a conductor of electric power it will spoil the entire circuits of it. in this case there is very rare possibility to cure. any how please open your camera and take out the LCD display, there may be corrosion on the clipping connectors, try to clean all the connectors, wash the total circuit board with cleaning liquid, re connect all then power on.
Nov 15, 2015 | Sony Cybershot Dsc-w330 14.1 Mp Digital...
My droid 3 fell into the sink and got wet, it wasn't totally submerged it splashed into a dish that had some water in it, I put it in a bag of rice overnight and when I turned it on this a.m....
First thing is take out the battery and dry the battery with a towel or paper towel. Allow it to dry for a while and in the meantimelet you phone dry out. There is suppose to be a seal around the phones main board to keep out moisture so if it didn't get to wet it should be OK. After about 30 minutes the battery should be dry enough to put back in and then try to turn the phone on. In most cases it will work.
Sep 07, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
What do i do when my camera got wet and it wont turn on?
It all depends on if it was totally submerged or if it was slightly exposed. If it was totally submerged, there is not much to do at this point. It will need to be replaced. The entire unit will not work as designed, due to the severe water damage. Now; if it was slightly exposed to a minimal amount of liquid, simply, separate the internal component and batteries away from the cover housing and let them dry out for 5 full days. Once the dry out period has been completed, reassemble the unit and load a fresh set of batteries. It should work now.
NOTE_ The dry out method will not work if you have already tried to operate this unit shortly after the water damage occurred. Energizing a wet system board will cause a short,thus, damaging the entire unit.
Aug 10, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-t77 fell in fresh water
Hello :
Please read this solution here . Please give the solution a try . It has worked with alot of mini devices just like your Camera .
good luck .
please don't forget to rate !
Apr 07, 2010 | Sony Cybershot DSC-T77 Digital Camera
My honda SiR was submerged in water, what are the possible problems (mechanical etc..)that will occur in case it will be repaired?
It depends how deep the car was under water. If the computer or any electrical componets got wet, they are total junk now. Water destroys these items
Jan 25, 2010 | 2001 Honda Civic
My g1 fell in water but not fully submerged in
http://www.fixya.com/support/r3771170-phone_water_damage
Nov 05, 2009 | HTC G1 Smartphone
My sony cybershot is fell on water and its not
listen to your service centre advise!
ITS DEAD and has no understanding of REINCARNATION or raising itself from the dead.
Unrepairable means just that, it cannot be repaired because the water would have shorted out most of the motherboard. The cost of any repairs if there were replacement parts ( which there are not) would exceed its value
Jul 06, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
Battery?
     You have to change the bettery but also check that the board from which bettery pass the supply it could also be short due to water.In this case it is not necessary that battery could be damaged.
 Thanks and dont forget to rate .
Nov 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc p200 water damage
salt is electrically conductive when in fluid (water) so when it happened i hope you pulled out the battery and protected the delicate lenses. a digital cam, is very delicate but their are companys that repair water damaged goods like mobile phones etc! just look them up in the yellow pages etc... avoid trying to switch it on until it gets repaired, but the mem card should still be fine depending on how long it was wet for! good luck!
Sep 22, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
125 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
