Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
I borrowed a poulan wild thing leaf blower. It worked for a few minutes and stopped. I added more fuel and when I tried to start it again, the pull cord woildn't cone out.
  • Jim Giesen May 11, 2010
    Did you put oil in the fuel? was it run before with out oil..remove the exhaust and look in the port to see it there is any scoring on the piston. large lines runing down the piston is bin time, small lines going around the piston is OK. Usualy if it was running then stopped and cant pull over, the engine is siezed from low, incorect type (marine) or no oil in fuel.... Some time you can be lucky like a customer this week He was filling it straight out of the pump, I put some oil in the port and rocked the engine over, It still had compression and got it to fire up. how long it will last who knows...
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    did it run out of gas or was it just low? did it make any noise when it died?
3 Suggested Answers
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
I have a poulan leaf blower that will not start.it sat for 2 years started once for about a minute
get a new plug and then check for spark. a spark checker is a better choice...and since I would be more inclined to believe you're not getting any fuel replace the carb and fuel lines. it's a waist of time trying anything else. just because you have fuel in the primer DOES NOT mean gas is getting to the engine. If you DO NOT have spark, but you have fuel, your spark plug WILL be fuel fouled (soaked with fuel)
Oct 16, 2014 | Poulan Garden
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan Pro BVM200 blower that will not run. I've cleaned the carb, changed the plug, and added new gas. It will fire up with starting fluid and die within two seconds. I tightened the head and...
turn the needles all the way down to where they just stop dont tighten to tight just when they stop then back them out 1 full turn and see it should start then adjust from there if no start or runs wildly then a carb kit is needed
Feb 13, 2011 | Poulan Garden
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan leaf blower won't start
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I replaced both broked fuel lines and it still doesn't start.
Make sure the line is connected to the fuel cap if it has a pump ball.
Apr 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Runs fine &then suddenly stops
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Dec 24, 2008 | ECHO, Inc. PB-251C Handheld Blower
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
113 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
