Question about LG 42LG50 42 in. LCD HDTV
DVI-->HDMI cable causes tv speakers to hiss and pop
I'm trying to connect my HTPC to my 42LG50 with a DVI to HDMI cable. I have a minijack cable carrying the audio.
When I have the video cable connected, the tv's speakers hiss and pop. The volume control and mute button do not do anything. When I switch to the DVD player on a component input, the sound works normally.
I tried connecting my iPod to the audio in, just to make sure, but that sound did not come out of the speakers, just the hissing.
I connected my macbook to the tv using the same cables and it works fine.
I'm going to try upgrading the video driver to the very latest, but I'm not sure that'll do anything.
My HTPC is running SuSE Linux 11, and has an Nvidia graphics card.
Check the tv's setup menu to see if you can reassign the audio for that input to analog only
Posted on Aug 23, 2009
  • 126 Answers
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Posted on Dec 25, 2008
  • edmeades Jun 02, 2011
    It's an issue with the Nvidia Linux driver. I'd rather not spend 50 of any currency unit when I can just mute the TV's speakers.
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
Im trying to use my TV as my monitor for my pc?
What problem are you having? The connection should be fairly straight forward depending on your computer's video out. You can use a VGA cable, DVI to HDMI (check your graphics card manual for single link or dual link on the DVI side), or component video (even S-video). If you have HDMI out on the video card, use an HDMI cable. If you want to connect to the TV's speakers, you need at least an 3.5 mm audio cable (or 3.5 mm to RCA audio).
The DVI cable can be either a DVI to HDMI cable or DVI to DVI or HDMI to HDMI with a DVI to HDMI adapter at one or the other end.
I hope this helps.
(you will need to go through the input modes to find the signal. Some TVs need to be on (with no signal) before the computer is turned on.)
Feb 22, 2010 | Protron PLTV-3750 Television
Can I hook my pc to my sound system
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on HHTS(Home theatre) (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on HTS. If no picture on tv make sure you computer graphic card is set for dual display .
Aug 29, 2009 | Panasonic Home Theater System System
Can't get sound when used as computer monitor
comp sound Tv
Your cable must be a minijack to 2RCA. Minijack connected at line out on computer and 2RCA at AV1 in or other available port in on TV (white and red socket). That is sound only. Video will be yellow (or vga/DVI/HDMI depending on graphic card)from your graphic card to AV1 in. same port as sound. Now select AV1 on tv. If no picture on tv make sure you computer graphic card is set for dual display .
Feb 02, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Panasonic plasma vieta
I just bought a Panasonic TH-42PZ800U and had the same problem. 10 blinks and the TV would not start. Then after some trial and error I solved the problem!
Here is my (apparent) observation and solution:
I had only one input into the TV, which was my HTPC connected via a DVI-to-HDMI cable plugged into the Panny's HDMI 1 slot. *IF* the HTPC was already on, then the Panny would have the blink of death. *BUT* if the HTPC was off, the Panny booted fine (assuming I cleared the blink of death first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off).
My solution was to move the HDMI cable from slot 1 to slot 3. After making this one change, everything worked as it should. No more 10 blinks of death. I could even leave the HTPC on and turn on the TV last, and it still worked. Tried this 10 times, worked 10 times.
I don't know if this will solve other people's problems, but I hope it at least provides some clues. I wonder if this is a fundamental circuit design flaw on the part of Panasonic, rather than a "bad batch of parts" problem.
Thoughts? Feedback? Send to gcpien at hotmail dotcom
Jun 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
The front led flash 10 times and the tv no turn on
Change the P.A board resolve problem. try to buy in www.shopjimmy.com.. if the front led flash 10 times is a tunner voltage problem.change this board. The P.A board Number is TNPA3620
May 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Feb 24, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv will not turn on
Possible power supply panel faulty.
Feb 09, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
No AVC media box
You should be able to use this with only the DVI connection as just a large monitor. You can use a DVI to HDMI adapter as I do believe the display is HDCP compliant. Many AV receivers will upscale to the necessary 1920x1080p resolution that the display needs.
Oct 29, 2007 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
LG 42LG50 42 in. LCD HDTV Logo
1,048 people viewed this question
Computer Repairing
Computer Repairing
