Router connects fine to compuuter but low connection to wireless connection
    Problem Solver:
  • 26 Answers
Try using a signal booster, about £10
Posted on Nov 26, 2008
I have a Zyzel nbg416n wireless router. Ive had it for 5 days and its constantly dropping the connection. Connection via an ethernet cable is fine, it's just the wireless aspect. The connection...
Wireless routers do what is called signal shifting. This means as the signal gets weaker (either because of distance or because it has to pass through walls, strong electrical fields etc) the speed is automatically dropped to as low as 6mbps. All the obstacles will kill your signal very quickly as well. You can try moving your router to a better location or invest in a repeater to place between your wireless router and the computer.
Sep 15, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Lose connection to internet at random times
There could be several things that can cause this problem, ranging from low signal strength, electrical interference, clashes with other wireless routers in your area etc.
Please click on this link and follow my instructions for possible solutions to your problem :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
May 12, 2010 | 2wire (2701HG-B) Wireless Router
Just bought new laptop with window 7 i alreadu have a desketop ant two laptop using window vista on network the new compuuter won t connect
first be sure to check that your wi-fi in on on your laptop. the next step is to reset your router, if that does not work, reset your modem as well.
Mar 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Problem connecting wireless to a Netgear MR314
Login to router and change the wireless channel on which the router is transmitting wireles signals.
Pretty old router that you have. Ugrade your router and stay tension free with the newer routers as they work fine and have low downtime.
May 16, 2009 | NetGear MR314 (MR314NA) Wireless Router
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Wireless connection
You should be able to reset the router.look on the back and see if there is a small, paper clip size, hole. Reset it back to default and try to reconnect.
Feb 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Having Problem Acquiring IP Address
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 19.168.0.240. Hope that helps.
Dec 25, 2007 | Linksys Wireless-G Range Expander (WRE54G)
No connection
One thing to check is to make sure your dad connected to your wireless environment because so many people have wireless routers today he may have accidentally connected to a neighbor, and the low/non-existent signal strength will cause him to not have an internet connection. Also make sure no one messed with the router configuration because there is an option to turn off the wireless capability of the router. If it got turned off then turn it on and you should be good to go.
Aug 28, 2007 | D-Link AirPlus DI-614+ Wireless Router
Wireless router dropping then disappeared
If other wireless hosts are connecting to the wireless router with no problem, and the windows laptop intermittently connects, then this seems to indicate a problem with the wireless card in your windows laptop. If the device is still under warranty, it should not be a problem to contact the laptop vendor and have it replaced.
Sep 20, 2006 | Zyxel (91-004-361002) Wireless Router
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
