Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a Phillips projection TV Model# 60PP9202 Chassis # DPTV305F with a linear distortion problem. The colors are not aligning. Can I fix my TV myself, or do I have to take it in. Any advice would be appreciated. Jim
  • 1 more comment
  • danindfw1 Nov 28, 2008
    I've been told the bulb is going out of my Phillips. How can you tell? Is it hard to change ?
  • secondhand65 Dec 01, 2008
    My housemate is a mechanic with circuit board soldering experience. Please let me know what is involved in replacing the convergence IC's. If we are skilled enough, is it possible to avoid the repair costs? I appreciate your help!
  • Anonymous Jan 18, 2009
    same model with colors not aligned on screen:all colors are projected as individual images but not aligned so that there are multiple images-i cant tell if it is triple vision or more.What is the solution to this.i have no mechanical tv experience
    chs
  • 106 Answers
It soundsa like you have a convergence problem. Probably only one color. (The green and red may be ok but the blue is bowed or any of those combinations) This will require the repklacement of convergence IC's and then alignment. Probably best to have a experienced tech take care of this.
Posted on Nov 26, 2008
My Philips HDTV 60pp9202/17f chassis: DPTV305F picture has problems. It appears "fuzzy" and "cloudy". I've tried to go to picture options and adjust the tint,sharp,brightness, etc.. and havn't come to the...
Thats indicating that the coolant in the three CRT's need replacement. The phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Aug 09, 2010 | Televison & Video
I have a dptv305f phillips tv and the color is almost foggy and it seems like the colors are really green or red
Very common problem caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit at www.tvrepairworld.com which also comes with instructions.
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Picture quality of colours fading
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center...
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
My rear projection television looks like it is 3D
replace the lamps and then run the synch routine from the main menu. unfortunitly with the expense of the lamps and the low price to replace projection tvs it might not be worthwhile to fix but just replace.
HINT wait till after new years, LCD large screen tv sold about 35% of what was expected during xmas so they will be real real cheap after the 1st of the year
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Dull picture, whites have halos, need to watch tv thru dvd player
the picture color problem is the coolant in the CRTs. You can get the coolant replacemnt Kit at the following link. The other problem with the Input through DVD sounds like the signal board. You can get the replacement board and the Phillips CRT coolant kit at the following link.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 66P920217F Chassis DPTV305F
there are some resisters that should be checked
other than that make sure you have all the connectors plugged in correctly
heres some diy sites.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 12, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
