Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Misubishi WS-65613 Flashing green reset light
Misubishi WS-65613 has a continuous flashing green light. I am a former TV repair technictian and have the tools to fix the set with some recommendations. I assume I will need to secure a copy of Sams Photofacts.
Thanks for any suggestions.
Frank
Austin, Texas Mits WS65613 replaced four Caps on DM - all previous four on original board were bulging..... powered up and still the same blinking green light -- any other new ideas ?
  • Anonymous Jan 05, 2009
    a blinking green light and it stays the same
    Tv does not turn on
    I tried to reset and it did not help.
    Thank you
  • 905 Answers
Do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Posted on Nov 26, 2008
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
It will not turn on.
i have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Nov 09, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Cant start on and the the green light keeps flashing
ardnas1886, can get the 4 new capacitors 1000uf 35v (Radio Shack part # 272-1032) = about 5 dollars
Nov 08, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
You will not need SAMS on this one,Frank! I fixed four Mits. with
your symptom in the last two weeks.....parts = 1000mf/25v caps
105 degree hi-temp X 4.......Location = DM module...for pix's...
www.Chris@ChrisAndNat.com.....download copy..........
I have improved above procedure....When finished with repair of
PCB.,I place it secure in sockets , with two screws on end of
module back in place.THEN I slide cover down over module
and put the side screws in..........
Be gentle and if you need more help............T.
Nov 25, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
310 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
