Question about Canon PIXMA MP130 All-In-One InkJet Printer
Waste ink absorber is full
What do I do as can't see what an absorber is and how can I correct the problem. Is it cheaper to buy a new printer/photocopier as use Pixma MP130?
Hope you can help
thanks
Evelyn
    President:
  • Canon Master
  • 1,447 Answers
It is problem there many waste ink fall a pad it was most derty then printer call a service
you are a technician you clean it and change new one pad it is like a foam and reset it
Posted on Jul 24, 2009
  • Sazeed Computer
    Sazeed Computer Nov 25, 2009
    Hi
    If you are not solve this problem.Please you go to a service center near in your area.They solve it by diagnosis software.
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
I hope this help!
Posted on Jan 15, 2015
  • 19 Answers
Waste ink pad are not too expensive but they are messy and time consuming to be repleaced by a tech. If u can get another printer with new inks for under a couple of hundred bucks, then i would suggest getting a new one.
Posted on Jul 15, 2009
The waste ink abosorber is almost full This
Pixma MP520 Printer. Waste ink absorber is nearly full message.Anyone know were to buy a new one.
Apr 14, 2011 | Canon Pixma MP450 All-In-One InkJet...
The waste ink absorber is almost full.
Hey!
Well you can still use it un till its completely full and then unfortunately buy a new one as even the manual says replace the printer as it has failed!I think its because it will be cheaper than having the old one fixed!
Sorry!!
Jan 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The wast ink absorber is almost full
the waste ink absorber is a small unit inside the printer where the waste ink goes in. it is a common problem in cannon printer. the ink absorber cannot be replaced mate so when it says full, buy a new printer because its not worth repairing it.
Jan 06, 2011 | Canon PIXMA iP90 Mobile Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Waste ink absorber is almost full
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I AM GETTING A MESSAGE EVERY TIME THAT I PRINT THAT THE WASTE INK ABSORBER IS ALMOST FULL. WHAT IS THIS?
It is a reservoir inside the printer that picks up all the excess ink when you clean the heads, etc.. It eventually fills up and has to be serviced or replaced. It might be cheaper to get a new printer. I see them on ebay for about $39. It will cost you that much for the new waste ink absorber...
Jan 20, 2010 | Canon PIXMA iP1600 Printer
Had the message waste ink full. Dealer said it would be cheaper to buy a new printer. Took out the absorbers and cleaned etc., now have an error message 5BOO. What does this mean? Thank you Iain
Here is the link for the Canon website for your product. If you click on the support tab you can put in a question to help you resolve problems.
Here is what I found:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer.
Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible.
Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. "We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
I have found out how to reset the counter :-
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button FOUR times
5) Press the Power button to turn the printer off.
This should reset the counter.
The replacement kit for the absorber is
Ink absorber kit (QY5-0146) I am still trying to ascertain exactly where the pad is located.
Hope that will help you.
The dealer was probably correct that it would be cheaper to buy a new printer - I just bought a 4 in 1 lexmark for $49 from a well known office equpment store!
Jan 17, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
242 people viewed this question
old marine
old marine
