Dark panasonic PT-61G63W TELEVISION
Hello, I read an awnser you posted 2 years back or so about how you thought that maybe a power sorce had a bad conection. Did you mean the high power out put or the regular transformer from 120 down to system voltage? My screen got dark and i have to crank the brightness all the way up to get some picture out of it. It's a little fuzzy but clear. Thanks for your responce.
techman
  • 3130 Answers
SOURCE: Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
Posted on Jun 05, 2007
  • 375 Answers
SOURCE: Panasonic PT-47WX42F
go to servicemanuals.net
Posted on Sep 06, 2007
premtech
  • 934 Answers
SOURCE: Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Posted on Dec 11, 2007
SOURCE: Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Posted on Jan 06, 2008
  • 4 Answers
SOURCE: picture fuzzy on dark scenes
hey all...just to let you know, I had noticed a post that said the individual prior to getting or ordering new parts, he took the tv apart from the back, and cleaned.
My husband spent the better part of the day, vacuuming out and blow drying on cool all the dust and such. after doing this the picture was worse, HOWEVER, we noticed the flashing was gone. SO, he took it apart again, and this time, very carefully took apart the compartment holding the color wheel. He took out the lens, cleaned it with a lens cleaner cloth. Took out the color wheel, very carefully cleaned the wheel, cleaned out the whole inside of that compartment, put it back together, and VOILA!!!!!!
BRAND NEW PICTURE EVEN BETTER THEN WHEN WE GOT IT.... no lies, no problems, it was extremely time consuming, but I ccan't describe the difference.....UNBELIEVEABLE and no spending a grand on a part.
Don't hold me responsible for any problems, but this just worked for us, and my tv is NO LONGER FLICKERING,, NO MORE LAVA LOOKING COLORS, NO SHADOWS.
JUST CRISP! WOO HOO, I DONT HAVE TO BUY A NEW TV... yet.
Posted on Feb 01, 2008
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
TV Won't Turn On
the lamp is bad. panasonic has a 5 year part warranty on the lamp and 2 years labor
Oct 18, 2008 | Panasonic PT-61LCZ70 Television
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
My darks are to dark on TV
what happens if you adjust the contrast or brightness?
Feb 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
DLP Powering Off after 5 minutes
Chances are the cooling fan for the lamp is bad, or the temp sensor for the lamp might be defective.
Jan 04, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-61G63W Too much Black Serial No: MY83430025
The mirror should also be cleaned. but there is more adjustments that can bring up brightnes ie G2 on the flyback transformers but that is some thing a tech should do. Because you have to ad enough of each color to get a gray scale. if you are off the picture will be tinted and your color will be way off.
Dec 26, 2007 | Panasonic PT-61G54 61" Rear Projection...
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
