Just fixed this problem. I did this;1. turn off water to machine and undo intake hose (top right at the back)2. take top off machine
3. Remove intake filter by removing screws and wires ( be careful of any wiring in machines as some holds a charge even when unplugged)
4. Remove soap tray compartment (be careful of pipe coming out of the bottom)
5. Clean all parts removed do not get electric transistors wet!!! make sure all lime scale is removed
6. Look at filter if badly damaged or dirty seek advice as mine was not I didn't need to worry
7. Put back together in reverse order!!
Hope this helps anybody like me scratching heads and scouring forums
Im just fixing the same problem now and as weird as it is follow the cable down to the door lock inside the machine where the cable plugs into the lock mecanisum (sorry for my spelling) my cables are burnt/melted they need replacing, hope this helps
SOURCE: Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
