Question about Kodak EasyShare C613 Digital Camera
Camera is saying lens error111,0,0,25 when i try to turn it on, it shows that error on thre screen then shuts off
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
SOURCE: Lens Error 25
I had exactly the same issue with my camera. To fix mine I twisted the lens to the right while it was extended, it takes quite a bit of effort, try turning the camera on again and see what happens, if it doesn't work twist it back into its original positions again. When I did this it started working again, although the lens is not as smooth on extension or retraction as it was before the issue. Also take out the batteries in between use as they always turn themselves off and on which I'm sure is the cause.
Posted on Jul 14, 2007
SOURCE: Lens Error Message 10f, 1, 0, 0
I just had the same problem like 10 or 5 minutes ago. I think that I am going to need to get a new one, take it to a lens(camera) shop, get a refund or take the damn thing back..and or, get a "NEW" thosand(jkjk) dollar camera..oh! and did u know that now! at walmart they are selling a deluxe package that comes with this same camera for $147.99..I was so mad when I seen and heard that because my mom bought this SAME camera for the SAME pice that they are selling the SAME camera w/(with) more things included...grr, damn you koday(jkjkjk lol) any wayz, I think that i am going to trade it in for that lol...thanks ya..peace!
Posted on May 11, 2008
SOURCE: KODAK LENS ERROR 122 1 0 0
if your looking where it says lens error 122 then when you turn it on it will say it i have the same problem but worse
Posted on May 25, 2008
BillB-SA
  • 2761 Answers
SOURCE: kodak m753 lens error 101, 1, 0, 0
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 09, 2009
  • 102366 Answers
SOURCE: lens error 303
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 18, 2010
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
First a black screen, then a lens error
For the lens error:
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Screen says LENS ERROR
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2009 | Pentax Optio E60 Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Camera problem, shows "Acsess"...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 30, 2008 | Cameras
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Kodak EasyShare C613 Digital Camera Logo
16 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
