Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
WHEN I LOOK AT MY BACKUP LOG IT SAYS SKIPPED IN THE FRONT OF THE FILES. IS THERE A PROBLEM? WHY IS IT SKIPPING EVERYTHING
  • 1 more comment
  • aswegancab Nov 26, 2008
    I have the Seagate FreeAgent/Desk external drive 640 GB.
    Thanks,
    nothing happens
    Skipped C:\Users\Aswegan\AppData\Local\Microsoft\Windows\UsrClass.dat{a8a308e8-8a95-11dd-8e79-001fc6db1721}.TM.blf Not Supported/File skipped (backup of operating system files and folders ( those that have both system and hidden attributes) is not supported)
  • aswegancab Nov 29, 2008
    The very first backup said it was skipped.
    Scholar:
  • 126 Answers
If it's showing skipped, you may have to go in and adjust the backup settings again. Go into the settings feature and make sure you have the directories and folders you want backed up selected. If you are leaving certain files and folders unchecked the log file is basically telling you that you have chosen to skip areas of your hard drive to backup. If what you want is showing as "backed up' then there is no problem and it's telling you what it did per your selection.
Posted on Nov 29, 2008
  • Slick54 Nov 30, 2008
    In Windows Explorer go to tools, folder options, select view tab and unhide system and file folders, should backup fine and not skip now that they are unhidden.
  • 849 Answers
It is not a problem, may u have block the popups. go to the setting option change it from there.
Posted on Nov 26, 2008
    Master:
  • 505 Answers
Its a propblem with the Operating System. Go to the following microsoft article. It will show you how to modify the registry to get rid of the error.
http://support.microsoft.com/kb/104169
Thanks
    President:
  • 1,901 Answers
Most backup utilities will skip files that have not changed since your last backup. Why rewrite it? It just saves time.
  • 13,433 Answers
Seems it has skipped backing up some files, do you get a error message or what happens? are the files aready backed up? so its automatically skiping them as the files are already on the drive?
  • 685 Answers
When you click on the ones that say skip what happens?
  • Juanita Vega
    Juanita Vega Nov 26, 2008
    im glad that helped you thank you for using fixya
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Slant o matic 401g skipping stitches what is wrong
Make sure you are using a brand new needle. A damaged needle will frequently cause skipped stitches. (Changing the needle is the least expensive repair for machine problems!!!!)
There is a lot of information available on the internet.
Nov 17, 2016 | Sewing Machines
DOESN'T APPEAR TO BACK UP ALL FILES
Did you use the software provided?
If so, go to "my computer> Look for your drive > Right click > propties > Scan disk.
Good luck,
Jul 14, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I get a backup, but with a lot of error messages
Microsoft has some hidden directory levels and files in VISTA and in XP that are visible only when the settings for the directories in which they exist are changed from the hidden setting.  It's tedious, but possible.  I assume, then, that what you were unable to copy to your backup are these hidden files.  They're placed that way as a default in the Windows install to protect the user from accidental "mistakes". Example:  Under "users", {name},AppData,Local,...
Dec 17, 2008 | Maxtor OneTouch 4 500GB External USB 2.0...
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
64 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Steve
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
