Question about Frigidaire PLES389D Electric Kitchen Range
I have a frigidaire PLES389ECC. One of the knobs for an eye on the stove top is in the off position but the display shows it on low. This setting will automatically jump to 2.0. Heat is being given off from the eye. I can't get it to turn off. Do you have any suggestions?
  • kfyearout Apr 29, 2009
    warming eye will not turn off! it is in the off position, but the light is still on and it is still warm. the first time this happened, we flipped the breaker and it went off. this time, no luck.
    President:
  • Frigidaire Master
  • 2,651 Answers
Remove the knob fist off and try using a diff knob, perhaps the back of hte knob has become strepped and/or cracked. afeter removing hte knob see if you can manually turn the switch off,if not replacing the switch seems the likely answwer, they call it a poteniometer, and each positon of "eye" has a specific one so order the correct one
Posted on Nov 26, 2008
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Frigidaire lr13824
Try Googling (Frigidaire)(lr13824)(manual) without parens.
Dec 24, 2017 | Kitchen Ranges
When any of the top burners are set to low
It can be (if it happens when the burners are on low). In that case you need to adjust the burners (the directions are usually in the installation guide). With the exact model number, you may be able to find this online. In some cases, the problem also happens when you turn the knob for the burner from Hi to Low so you can check that as well.
On my stove, you turn on the burner and set it to Lo. Then remove the knob and use a small flat blade screwdriver in the valve shaft (or an opening next to the valve stem) to turn the adjustment screw. Then adjust the flame to the desired size (hold the valve shaft to keep it from turning with the screw). Replace the knob. Repeat this for all of the burners.
I hope this helps.
Jul 25, 2010 | Frigidaire Kitchen Ranges
Can you replace electric eyes with glass top?
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
Mar 27, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire ceramic cooktop burner turned on by itself
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 28, 2009 | Frigidaire FEF366DC Electric Kitchen Range
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Jun 15, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire PLES389D Electric Kitchen Range Logo
232 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
